georgeofthedesert
Hey,
I have a FWC Swift that has been on order for a while (placed last June) and at the end of this year/early next year it should finally be ready, so I'm starting to get things ready. The plan is to use airbags to help the suspension in the back. In my research last summer I came across something that I can't seem to find anywhere and I'm hoping this forum can help. I have no clue what it's called and I'm not familiar enough to know if I have the terminology correct, so hopefully this description isn't super horrible. The best way I can describe it was an in-cab controller for the airbags. Basically it was a small gauge (maybe slightly larger the deck of cards) they had in the lower left side of their windshield area. There were two digital 2-digit read-outs side by side that read the left and right airbag pressure. Above each of those was an up arrow button that will inflate the corresponding side. Below each pressure readout was a down arrow that would deflate the corresponding side. So the process to inflate the airbags is flip the compressor on and once it's ready you can inflate the airbags with the up arrow button to whatever the needed pressure was, all from inside the cab of the truck. With my searching I can't find that controller anywhere and what I'm finding will work in a similar but they are much much larger and less slick the one I saw (analog tacks and toggle lever switches). I thought it would be easy to track down later so I never saved it and it's been long enough that I can't even remember what forum/site/maybe magazine I saw that in.
Does anyone know what controller that was or have any that are similar?
