Schattenjager
Is there an advantage to losing the sway bars on an OME 2.5" lifted 80? I played around a little today and was unimpressed with the articulation.
Thoughts?
Thoughts?
Alvaro runs his 80 sans sway bars. It always a little unnerving to watch him, from behind, slalom through a paved corner at 75mph in full lean :Wow1:
Having ridden with him when he had no sway bars, I can tell you that truck was DANGEROUS.
Increase lift height to 3-inches (or more) so you can run the N74L long-travel shock (or equivalent).
[:brokenrecord smilie] lol. Maybe you should explain this? :coffeedrink: I kid, i kid.
Anyway...the real problem with running the front sways while off road on an 80 series is that the flex will tear off the mounts to the axle. When this happens, the end of the sway bar takes out the brake line. I have seen this several times including a memorable time at the base of cadillac hill on the rubicon. It is worth rewelding the mounts (easiest) or making new mounts (better) with a quick release pin. The original mount was just stuck there with a spot weld, and not up to toyota's usual overbuilt standard.
Anyone make a quick disconnect setup for 80's?
Anyway...The real problem with running the front sways while off road on an 80 series is that the flex will tear off the mounts to the axle. When this happens, the end of the sway bar takes out the brake line. I have seen this several times including a memorable time at the base of Cadillac Hill on the Rubicon. It is worth rewelding the mounts (easiest) or making new mounts (better) with a quick release pin. The original mount was just stuck there with a spot weld, and not up to Toyota's usual overbuilt standard.
