ShottsCruisers
An easier way to gain flex in the front end is to pull one of the control arm bolts
Slee warns against this from experience...creates other problems.
[:BROKENRECORD SMILIE] LOL. Maybe you should explain this? :coffeedrink: I kid, I kid.
Anyway...The real problem with running the front sways while off road on an 80 series is that the flex will tear off the mounts to the axle. When this happens, the end of the sway bar takes out the brake line. I have seen this several times including a memorable time at the base of Cadillac Hill on the Rubicon. It is worth rewelding the mounts (easiest) or making new mounts (better) with a quick release pin. The original mount was just stuck there with a spot weld, and not up to Toyota's usual overbuilt standard.
