would be easy to do so. Pythagoras solved it ~2500yrs ago. That and a little Trig (2300yrs ago). All you need is a base edge pivot setup and a pivoting leg or stirrup that is mounted on both 'side' edges, with that 'base' leg sized to match your panel to the optimum angle for your latitude. With an appropriate slot setup in your mounting frame all you'd need is a couple wingnuts / threaded hand knobs, loosen them, lift up on the high edge of the panel until the linkage maxes out, then tighten them. You could even add a pneumatic arm so all you'd have to do is loosen a knob and the panel pops open to height. YOu'd just have to push it flat and tighten the nut / knob (and maybe pin it to lock it down).
What I'd really like to do is mount a panel on a 3-axis wall mount for a flatscreen TV, such that the panel is flat and locked in a frame for transport and once in place just unlock a frame and lift up the panel to whatever orientation you need, regardless of which way your vehicle is oriented. I wanted to do something like that with my own rooftop setup, but wanted a flatter setup to keep the panel unnoticeable.
some noise I made about the idea, 2yrs ago -
https://www.expeditionportal.com/fo...-werks-topic-02-k1500-z71.172800/post-2386546
eta this setup would be widely adjustable to cover the full range from Tierra del Fuego to Prudhoe Bay, in any season / axial tilt.
If one could rig a sort of lazy-susan baseplate, you could spin the deployed panel to face whatever direction you want. You just spin it around and flatten it for road travel.
Here's now mine is now, details are on this page and prior -
Drove up to Vandenberg today to witness the SpaceX Falcon9 / Iridium launch, but mostly because it was to be the first attempt at re-landing the 1st stage on land on the west coast. Closest I could get was about 4.5mi from the launch pad, in the farm fields of Lompoc. Rocket went off without a...
I'm thinking about reworking the setup to have two panels on the roof, same sort of frame, with the forward panel fixed, with the portable panel remaining removable in the rear portion of the frame. Just need to find a ~100W panel that's no more than 44" on the long side. And up my fabrication game a little.
eta and wire them in parallel, so if I park the vehicle in shade and ground deploy the portable panel in the sun, the setup will still generate some juice.
