Tankless water heater for heat?
Precision temp RV-500 is about $1000 with the vent fan. The advantage of the unit is that it using out side air for combustion. You can't fire up a tagaki in a small tight space without providing air.
I'm planning to mount the Takagi waterheaters on the front wall of the outside of this box (inside the cab-over rack we made), cradled in isolated mounts.
Well, if you're concerned about the diesel, you probably won't be excited to know that the cabin heating unit, installed in the bottom section of the storage rack,, is petrol-fired. :Wow1:
You can see the circular vent for the heater output cut into the black bottom panel.
I've studied it, though, and can't see any problem areas. I'm content that it's a good safe installation.
Petrol fired cabin heaters, shades of certain air cooled VW's
MOLLYmaz
