TetonX 2020 F/S
adamalli
SOLD
TetonX trailer for sale. $36,000
Located in Denver, Colorado area.
Bought November 2020. This is the version before they went to a composite based build. Trailer has been used about 50 nights. Used mostly in Colorado and Utah. Always kept in a garage. There is nothing wrong with the trailer we just decided we wanted something that we could cook inside and outside. Specs of trailer below.
Cabin dimensions (external) 79” wide x 62” tall x 119” long.
Overall length w/tongue, without spare tire 173”.
Overall height from ground to top of roof vent 86.5”
Base Weight Approx. 2800lbs
Passenger side lockable door and screen door
Driver and passenger side opening window with integrated blinds and screen
Diamond plate stone guard
14” powered roof vent
Rhino Rack Vortex roof load bars
Split queen mattress 76x76
Dinette table with leg, converts to form bed platform
Exterior front side storage door with large storage area
6’4” tall standing area with pop top deployed
Timbren 3500lb independent Axle-less trailing arm suspension
2" lift
2” x 3” Steel tube powder coated chassis
Integrated 1.25” brush guards
Electric drum brakes
15” x 8” alloy wheels with 31/10.50 all terrain tires
7 Pin trailer plug with chassis wiring
Added HaloView Rearview Camera system. Screen mounts on tow vehicle rearview mirror, 5v usb powered. Camera on trailer is powered via 7pin trailer plug
KITCHEN
ARB Classic 78L refrigerator on pull out tray on heavy duty locking slides in front cargo area
Slide out kitchen in rear cargo area. Built in Dometic sink with tempered glass lid and 2 burner Partner Steel stove in a 48”x19” counter top. Includes a 42”x19” slide open table to double your prep space.
2 drawer cabinet on fridge slide
WATER
40 gallons water tank,
Truma AquaGo Comfort Plus On demand hot water heater with recirculation and antifreeze kit
ELECTRICAL
Renogy 170Ah LIFEPO4 battery
Redarc Manager 30 - shore power, portable solar, and vehicle charging all connect through this. Trailer has an anderson connector that can be connected to a vehicle with a matching connector to charge while towing.
Solar port for portable solar and roof dual port for additional solar
Inverter with transfer switch
GFCI outlets inside cabin for entertainment power, under kitchen draw, and in front storage area next to control panel
Exterior lighting - left, right and rear all individually controlled
Exterior rock lights
Interior lighting - 4 LED interior lights
12 volt power port as well as USB power port inside cabin for device charging and further entertainment connections
12 volt power port externally mounted by awning hinge for additional awning lighting
Light in tongue box, only switches on when box is opened.
Added two reading lights and two 2 - 60w USB C chargers
SHADE AND PRIVACY
OVS 270º awning
IronMan fold out privacy room over shower fixture
Heating
Truma Varioheat
STORAGE
55” Weather Guard Chest Tongue Box
RotoPax locking mounts - rotopax containers not included
Spare Tire with mount
COUPLER
Maxcoupler articulating hitch
PROPANE
(1) 10lb bottle and locking bracket. Rear bottle runs Partner Steel stove
(1) 20lb bracket, no bottles. Front bottle runs water heater and furnance.
adamalli
Additional Pictures
bdpkauai
