This weekends project, 35" on a Quigley. (DIY Fender trimming)
Thanks for sharing this. How much faster are you able to air up with the 35's now?
About 10% quicker. Still takes too long even with onboard full duty cycle twin compressors and a 200psi tank.
Faster? 35s will take more air than 33s.
Surprisingly they actually take less air, since the 33's needed to be run at a higher pressure since they were narrower.
I spent a ton of time working out all the options, created a spreadsheet that calculated all the differences between different tire setups, including air volume.
285/70/17 holds 5750.96 cubic inches of air and will take 110.08 gallons to fill @65psi.
315/70/17 holds 7379.06 cubic inches or air and will take 97.78 gallons to fill @45psi.
Here are all the others.
tbnd88
