UK4X4
"Just start building the darn thing"
he's been pondering this issue for a year already.....in another thread
another few months won't hurt.......
eepwall:
mean while
the rest of us have been busy with the welder:arabia:
These threads help the home builder in many ways both from the idea's generated and the information provided.
Toe in / out on my design was slotted holes in one mount-
only one side needed it
Camber was going to be simply put a shim under the mount..
was'nt required.
I did not use a jig as such- just lots of clamps and measuring and the odd bash with a hammer.
Think of trailer suspension as rear's on trucks, really they don't effect the ride that much, hence the lack of adjustment.
Its not like front indy suspension on a truck which severly effects steering and tire wear.
Even if you were majorly off....with the average trailer usage....being a small percentage of time per year, you would probably have to replace the tires due to being old and perished before you'd worn anything down.
Distortion and movement can be minimised
Using heavy wall tube
tack welding all the pieces, beat to shape
then final weld in short steps, in diferent area's, keeping the temperature low
I'd say toe in/toe out on my indendant is about within 2mm and camber 3mm
I think watts linkages on a trailer suspension is a lot more work with no real benefits.
As soon as you leave the world of leaf springs-
cost and time to build mounts up pretty fast.
Air bags $ 150
Cheap shocks $ 60
air bag mounts $ 40
air bag plumbing $ 40
shock mounts $20
poly bushings 8 off $ 40
grade 8 mounting bolts 12 off $ 20
Bushing mounts 4 off $ 80
Axle 3500lbs complete hub to hub $160
$ 610
V's 1 off 3500lbs axle with springs and mounts for $ 240 (northern Tool)
Time....inde- 3 8 hr days
Standard 2 hrs
Anything bought piece part costs a lot more than standard off the shelf.
mean while
was'nt required.
Air bags $ 150
Cheap shocks $ 60
air bag mounts $ 40
shock mounts $20
$ 610
Standard 2 hrs
