zukrider
the idea of this thread is a central location for space and weight saving storage ideas.
so with this specific forum, it is obvious that there is a common factor of small. with me being a Sami guy, i am very used to maximizing storage and still being happy with the results. Samurai's also need all the help they can get when it comes to weight!
so here is my pre-curser. I am a crawler guy. but in colorado, there are just as many, if not more, of the easy scenic trails. also, just 10 hours away is moab. and since my tenure started at this great forum, i have been planing a lot more "out there" trips for the future. plans as of now are the full rubicon, all of moab, the hammers, alaska, BC, and more pop up all the time. when? well who knows!
also, usually, my samurai is my DD. so obviously it must maintain drivability. so my mods are crawler aimed, but expo met!
my gear set.
Always:
-full size spare
-2 tarps
-hi lift jack
-25' chain with 2 hooks
-30' x 3" strap
-recovery kit-tree strap, snatch block, 2 clevis rings, gloves, winch remote, small chain.
-full tool kit (tools that I need, not enough for all!) helps save weight
-fluids-gallon of coolant, 2 qts oil, gallon of 90 wt, pint of brake fluid, empty coolant jug for waste fluids.
-spare parts-3-5 u joints, front d shaft, rear dshaft, one each extra slip yoke, bolts and nuts variety, rod ends, fuel pump, throttle cable, clutch cable.
-safety-ratchet straps, flares, gloves, funnels, hand warmers, tire plugs w/tools, maps, fire starter.
-12" subwoofer! gotta have tunes!
-clothing-2 coats-1 water resistant, one carhartt heavy work style, carhartt bibs, good winter gloves, beanie. (colorado has teen temps in summer at the higher elevation trails)
-etc....jumper cables, gallon of water, nutrition bars, small back pack, bungee cords, zipties, duct tape, electrical tape, first aid kit, 2 flash lights.
i kid you not, its all in this pic, and 98% behind the seats!
in this one, you can see my fancy led dome light!
on top of that, i have a rear bumper, with halfwidth swing out made from .250 wall 2 x 4. both sliders made from .250 wall. front bumper made from .250 wall. warn xd9000.
when i go wheelin close, i add at least another backpack with a change of clothes, water proof jacket, sunglasses, sunscreen, food, and more flashlight. camping adds typical gear, chairs, cooler with ice and drinks/food, cooking stuff, tent, blah blah blah.
as you can see, i fit it well. i just did the organizing yesterday, and still have more to fit, but thought it would be nice to see some other ingenuity.
tips i can share.
on my rear door, ill be securing my driveshafts with conduit mini's. like these
my shovel will get quick fist clamps on the rear door.
also, i will have 2 drop down "tables" in this area as well. one aluminum for a 2 burner stove, and 1 from a uhmw cutting board for prep. these will fit behind the shovel, and in "setup" mode, the shovel will come down for access.
so far, it is suiting needs, because i can gas up, get food and go. the over all setup will change though. i plan to get a 43qt fridge, which will require a smaller sub, so at that time i will completely redesign and attempt to shave some more weight. right now, the sub box is integral with the supprt structure of everything. in theory, i should be able to roll on my lid and nothing will move.
so please chime in with ideas and pics if you have them.
my gear set.
Always:
-full size spare
-2 tarps
-hi lift jack
-30' x 3" strap
tips i can share.
