MCObray
LT 235/85/16 BFG T/A KO2s (Load Range E) or 265/75/16 Goodyear Duratrac (Load Range C)?
My current tire is a P265/70/16 Michelin LT A/T 2s, which has been a good tire (no complaints really). I commute 20 miles, 95% interstate everyday and am getting out once or twice a weekend per month on forest roads / trails / etc.
Either tire will fit on stock 1st gen suspension from my research. I am ok with losing 1 - 2 MPG going to a heavier tire. What I am really after is durability of a tire when out and about. I believe E is overkill for our trucks but I really have loved all the BFGs I have had in the past including a set of 265/75/16s KO1 on a 3rd Gen 4Runner. I have had the 265/75/16 GY Duratrac in a C on said 3rd Gen 4Runner and did not like them... ended up trading to the BFGs.
Would you...
A. Keep the P rated Michelins and have the slight anxiety of blowing a tire when off road (do not have identical spare).
B. Nut up and go with the tire you've had great luck with (BFG). $732 / 49.2 lbs
C. Give the Duratracs another go, all while saving a bit of weight & ride quality. $828 / 45 lbs
Thanks
Would you...
Thanks
