Arivalsend
Ok I have searched and have not found much on a problem that I am having. I wanted to start a seperate thread to address the problem aside from my build thread and so here it is. I have a 1999 Tacoma Ex Cab. I recently put on Donahoes/Deavers w 5100s. And Wheeler's steelies with Toyo AT's. After doing suspension and wheels/tires I have come to a problem that I just cannot figure out. I picked this vehicle up in very poor shape and so it may have to do primarily with a passenger side push on the cv and uca/lca. I have replaced everything but the cv's. And also had the frame straightened. The truck did drive after a bit of work and I did not notice a rubbing with its stock 30 9.5 tires and rims.
On bare pavement at any speed the truck has a very consistent vibration/rub sound. It increases when my tire speed/revs increase and is present if I have the engine engaged or am just coasting along with the truck in nuetral. It happens like clockwork and goes away once I hit a snowy patch of road. It happens if I am in 4wd or 2wd and seems worse when I am slowing down (ie I dont have power to the wheels). I can only come to conclude the it is drivetrain/tire related as it really only happens with this current setup. I have had the truck aligned and everything checks out that way. I have also done all the fluids and grease zerks in the powertrain (transmission, t-case, diffs). I have also pulled the wheels and had them rebalanced several times. I even went so far as to replace the rims in the advent that one of them was bent. Still no solution. I am running 265/75/R16 Toyo AT's. This is the first set that I have had but the noise seems far too consistant to be tire noise.
My one thought is that maybe I have a bent CV as I believe those turn irregardless of if you are in 4wd or not. I am really out of options/guess work here and am hoping for any info or thoughts. I figured if anyone may know its you guys. I am stumped and you know how that feels
Thanks all and let me know if I have left any essential details out of the picture.
