We spend as many weekends as possible heading into the Colorado mountains with our ancient pop-top Skamper slide-in on a 4WD (NOTE: I erred on initial submission be saying I had a 2WD) first-generation Tacoma. We're loving it!
I've milked two extra years out of the Wranglers that came on the truck when I bought it used with over 128k, but we got a puncture on a sharp-rocked trail that couldn't be repaired so it's time to replace them. (Riding at 60+ mph hwy after coming off the trail, I wondered why I felt more sway than usual. The wind? Gee, the trees weren't moving...
As soon as we stopped and the air in the tire cooled, the tire flattened like a pancake. Lesson learned!)
I've been a bit confounded by all the advice - often conflicting - about tires but I've finally decided to get at least a C-rated tire and may go as high as an E if it saves me money. Even though the load rating of many passenger-rated tires match or exceed the load rating of at least the C's, I have come to believe that if nothing else, the "thicker" tires will resist puncture a bit better, especially since I have to max out the air pressure in the passenger tires to cover the weight whereas I could have less pressure in the higher-rated tires to carry the same weight. My understanding is that airing down helps tires roll over rocks rather than popping like a balloon under pressure. (Though I admittedly don't know squat...yet...about manipulating the air in my tires depending on conditions.
So now my question is, do I need an AT tire or can I stick with an on-road tread? The consensus is that AT's are noisier and reduce gas mileage (ugh) so I'd rather steer clear. If you think I should go with the AT for safety in the back country, I'll decide between the Yokohama Geolander and the Firestone Destination.
Here's our driving pattern: I don't drive the truck much with the camper off 'cause I commute by bicycle so I can afford gas for the truck.
However, we often do a lot of highway miles to get to locations we want to explore so ride smoothness and better gas mileage are important. When we are off road - which we do frequently when traveling - the paths are often rocky/rutted/rough but nothing really scary and we don't do sand or rock shelves. We're often a little over our maximum weight what with the camper, two adults, and the dog despite carrying little water. We're typically driving in dry conditions but downpours are not rare so it can get slick fast. Being in Colorado, snow is a given in winter (and spring and fall, and even in June in the higher peaks) but we don't have the camper on then. I don't want to buy a separate set of snow tires since I rarely need them.
Have any of you run non-AT tires successfully under similar conditions? If so, do you have brand recommendations? Tough sidewalls is key. Or would I be foolish if I didn't go with an AT? (We did make it two seasons on the P's.)
Thank you for your feedback. (P.S. For those who remember my "project," I got the roof fixed. SOME day I'll post on all my fixes/customizations.)
