To K&N or not to K&N
Topgun514
My initial thoughts are no- after reading much about desert travel (I enjoy going to moab) can destroy your jeeps engine with one of these.
This is the box style, not cone. Going into a stock airbox with a hole cut in the side.
Thoughts?
I know this has been talked about tons but I want some jeep feelings on this?
Xodius
I had a K&N on my KJ and after about 2 years I took it off and checked the TB and it was filthy. So off it came an no more problems since. I try to stay away from them now.
PolarXJ
One was in my XJ when I bought it. I've cleaned the TB mutli times since I've owned it. What would be a good alternative to get the benefits of the K&N but not have to worry running it in the dessert?
Black Dog
Makin' Beer.
I'm also going to say NO! but from the opposite end of the spectrum-water. I have one on my XJ and hydrolocked my engine earlier this year, I think if I had the stock air box instead of the FIPK I wouldn't have sucked in nearly as much water and might have gotten through. Open element air filters of any kind really have no place on a vehicle unless it will never leave the pavement.
JIMBO
:sombrero: Well I live (sometimes) in the Nevada desert and I would never use an oil impregnated air filter--trouble
I use the K&N oil filter cause it's perfect for the JKU
Just get FRAM #10348 air filter for $13 bucks and changem when you want to !!
:costumed-smiley-007:wings: JIMBO
Maximus Ram
Yep..ran a k&n in the Dodge for years. Read some real life expierences with them an dthe instances with dust. Changed to a napa auto gold filter. Dodge seemed to run and breathe better the last time going to Yosemite.
Still need to change out the one in the XJ.
Stumpalump
K&N is the best filter for dust if you add oil to it. From the factory they are reatively dry to max out air flow and HP. I run them on everything with extra oil and I think they rule. I've been using them on and off road for 20 years and the one I put in the wifes car got extra oil and I siliconed the airbox shut. I'll never ever touch it again. As the dirt builds the oil wicks out onto it and then the dirt itself is a sticky oil covered particle that collects the next piece of dust. Buy a can of oil and oil them up and you will see no dust getting past them or dusty oil covered crap on your MAP sensor.
winkosmosis
No, nothing but bunk for people who don't know any better or get their automotive knowledge from shows on Spike. They let through 45x as much dirt as paper filters.
http://forums.nicoclub.com/debunking-the-k-n-myth-why-oem-is-better-t180100.html
wjeeper
winkosmosis thanks for that link! Made for an interesting read for sure.
I too had a K&N before I knew any better and like the others I either got dust past the filter or oiled the filter too much and killed an expensive MAF sensor.
I have always said if the K&N filters are so magical why does no car manufacturer use them? There is dang good reason!:snorkel:
halpeters
K&N filters are at best a waste of money for a Jeep, and at worst going to damage or accelerate engine wear.
The purpose of the K&N filter is to increase air flow through the engine to increase power output. This is good for race cars, but for any engine, the effect will only be of benefit at full throttle. How often do you drive at full throttle in a Jeep? not very often...
So - waste of money, for no benifit, and high risk....
just my thoughts.
CJ7nvrstk
Am gonna step out on a limb here. (Flame suit on)
I have been running the K&N filter element in the stock airbox of multiple different vehicles here in the desert for many years and not had ANY problems with them. To those that say it will allow more dirt in and damage the engine, I have yet to see that. Even on an F150 with 180k miles on it and NO problems.
For those that say the added air flow is off no benefit, I say bull. Here is something I want you to try: duct tape your mouth closed and shove a cotton ball up one nostril then go run 5K. AFTER you do that, and that means only after, come back on here and post that you noticed no difference between that 5k run and any other. You won't because there is a difference throughout the rpm range.
winkosmosis
How would you know whether there's more wear on the engine from the additional dirt that IS getting in? A lot of people will say they haven't had any problems... Is that good enough reason to do unnecessary harm to your engine?
But except at full throttle, the throttle plate is restricting flow purposely. So the only time you benefit from the freer flow is at full throttle
Sfreeman
