javajoe79
Fabricator
So should I swap to a straight axle or do some sort of custom IFS with beefier parts? I would like a decent ride quality but I feel like I can obtain that with good shocks and components in a straight axle swap.
With my upcoming engine swap and addition of the camper to my S10, I am considering a straight axle swap in place of the rather weak differential and IFS. Going with 35" tires and hoping to lift the truck as little as possible so I will be using full width axles to help with turning clearance for the tires. I have a dana 44 form a wagoneer but I also have a front differential from a brand new diesel Titan as well as the CV axles so I could come up with some custom bits to make all that work but I am not sure the gearing would be right and it would be difficult I am sure to obtain alternate ratios for it. I would like to use the typical chevy 6 bolt pattern as it is common and makes for cheaper wheels etc... Either way I would use coil springs, be they coilovers or a conventional spring and shock setup. I have full fabrication capabilities to make anything I need like custom control arms, links, brackets etc... Can also remachine hubs for different bolt patterns etc...
Basically just tossing ideas around at this point. Please weigh in with your opinions, facts, info etc...
