Toyota 4.0L Musings
Clutch
<---Pass
This is good feedback to hear. Front rotors are one the near term list, as are SS extended brake lines. There are several rear disc conversion kits, but I have found very mixed and limited feedback on effectiveness and function.
Rear disk conversion is probably over kill, unless you are a very spirited driver. Believe I still have the original shoes on mine, though it has lived most of its' life running with bed nearly empty. I have a bout 300 lbs. back there for DD use, that is just to keep my HD Dakars from rattling my teeth out... ;)
Forgot to mention, use high quality brake pads too. They come in all different grades...so it is hard to recommend what will work for you.
robert
There are at least two disc brake conversions out there put together by the same company (or were anyways)- one used Ford calipers and the other, which was a lot more expensive, used Tundra parts. For most uses the drums seem to hold up pretty well though; I've got 130k on mine and they're still in good shape but I have swapped front pads to a set of Hawks. The pads I took off were still in decent shape though.
Caoboy
Do the 4.0's still have head issues? I remember a thread or two on here a couple of years ago about the 4.0's having head/gasket problems.
Plannerman
Wandering Explorer
There was a head gasket issue on the 2004-2005 4.0 (4runner and Taco), but it was resolved with a redesigned gasket in 2006
Sent via fat thumb
Mrknowitall
Thanks Mrknowitall, very helpful. So, if the Tacoma had better breaks (front and/or rear) and improved springs, it would conceptually have a higher GVWR?
Conceptually yes, but not from a legal stand-point. Unless you have an inspection entity in your state willing to enter a higher GVW for you, the OE GVW applies. That doesn't mean it is necessarily ILLEGAL to drive over GVW, it just exposes you to greater liability, should something bad happen.
I'm guessing the rear drums are also a cost-based decision? And what is the BW transfer case?
Yes, te drum are definitely a cost-saving feature. Good part is, that in the real world, parking brakes tend to have more holding power than hat-style brakes that are common with rear disks.
BW transfer case? The Tundra recently switched to a transfer case supplied by Borg Warner, rather than an in-house/Aisin unit. That doesn't make it inherently bad, but it just seems like watering down of the vehicle. Since the Tundra case is somewhat low volume within Toyota, they probably realized big savings by outsourcing a unit that is similar to the one in the F150.
huntsonora
I get better mileage in my 5th gen 4Runner than my buddy does in his 2012 Tacoma and per those numbers the T4R has more HP and torque
jbg
The next Hilux and Tacoma are supposed to share more components, including a diesel- an updated 1KD with SCR technology (yay DEF!) That, along with a DI V6 should come with the A760 transmission. Hopefully they'll keep Toyota T-case, instead of the BW unit now found in the Tundra.
Mrknowitall, where have you heard this? I've never found any credible sources citing a diesel Tacoma, let alone one with a 1KD. This would be completely awesome, if so, which is why it cannot possibly be true. :sombrero:
Jim
bkg
Remember, these are completely different engines. My 10 Tacoma ranges from 13.7-16.8 on the highway (yeah... sucks) while my fiancé's 10 4Runner ranges from 19-24 on the highway... guess which one we use for long distance driving...
Around town, I average 15.3-16.4.... She averages 19+.
gp01
