1986 Toyota Diesel truck with 8700 miles. It is essentially new. The rear seats still even have the plastic covers on them. The gross vehicle weight is approximately 5000kg/11000lbs. It is a dually that is very heavy duty. It has dual engine brakes. The engine is the Toyota 13B. This is the direct injection version of the renowned 3B which was sold in the US, so many parts are available. Arguable one of the top Toyota diesels with all the advantages of direct injection without any of the electronics of a modern truck. 5-speed. New Tires. New fluids, belts, filters, battery. In Japan these trucks have to go through very rigorous regular maintenance and they do not use salt on their roads, so it has no rust. This truck is from Japan (JDM), right-hand-drive, with all of the proper importation paperwork. It has a clear Montana title and is currently in Helena. You can keep it as a firetruck or take off the pump equipment, which just bolts onto the frame, and add whatever bed you like. Here () is a sample of another firetruck with this aluminum bed (https://www.uteltd.com/) on it so you get an idea of what it looks like. It could easily be used as a tow truck or a dump truck. It has plenty of torque but the transmission is geared for heavy loads which limits the top speed. You can cruise on the highway at around 60mph. I will deliver it anywhere for a fee. $16450
