'05TJLWBRUBY
This will be a long, drawn out process, but I'll attempt a trailer build thread for my current project. I'm doing the build thread on a couple Jeep boards as well so some of this is geared at making it work with a Jeep. We have a number of other trailers at home and up at the ranch for various duties ranging in size from a 30' gooseneck to a 14K tandem, some stock trailers, and my little 5x10 I regularly pull behind the Jeep. The 5x10 handles most chores well, but lacks in a few areas that I'd like to address with this new trailer. If all our trailers saw was highway use, we'd be fine, but our property is 45 minutes off paved roads up in the mountains over rough road. Some gravel, some dirt and some classified as "improved" to say the least. When it's washed out, it's rough at best. Our trailers take a beating, as does our equipment or gear. When it's dry, everything gets covered in dirt and filth, as it also does when it's raining or snowing. I'm going to attempt to build this new trailer with full sides and a removeable locking top as well as tailgate to help keep things clean inside. It will be dual-purpose for camping, but also utility work as well. Rough dimensions will be around 4'x6' and around 30" deep or thereabouts. Haven't finalized any of this yet except that I want a full 48" INSIDE box width for sure. Track width will be pretty close to the Jeep and I intend to run matching tires/rims as the Jeep so I can swap the spare from Jeep to trailer as need be and cut down on weight/bulk by only carrying one spare instead of one on the Jeep and one on the trailer both. It will be built with off-road use in mind and intended to take the beating we dish out and HOPEFULLY hold up better than our other trailers, yet still weigh in light enough that I can pull it easy enough with the Jeep when fully loaded. I HOPE I can accomplish that when it's all said and done.
Let start with the parts list:
Here is the axle setup. It's a 3500# Dexter with 10" electric brakes. The Jeep track width is roughly 60" but I'm running Spydertrax spacers so I had the axle cut to 63" WMS to be close to the Jeep with the spacers included. Part of this also deals with measuring for springs centers and the fact that I want a full 48" INSIDE box width, and taking into account the measurements needed for tire buldge measured at the fenders and distance needed to the frame. For springs, I was worried standard trailer springs would be too stiff, so I went with the longest I could get at 27" and had them remove a leaf. These are "softride" spring packs 3 pack leafs 27" instead of the standard 24/25" 4 leaf pack you normally get with this setup. Also have a trailer break-away box, bearings, etc. The builder upgraded me to EZ-Lube spindles as well, where the entire spindle has been outfitted with a zerk, drilled and tapped with a grease channel feeding the inner bearing first, then grease flows through the inner bearing, fills the cavity and works it's way to the outter bearing. These are NOT your typical "bearing buddy" setup, this is the actual Dexter EZ-Lube spindles.
Next, for the hitch, I went with the Lock-N-Roll setup. This is the 6,000# rated hitch as I felt the 2,000# would not be adequate and obviously the 15,000# was a bit overkill. Obviously it's the 2" slip-in style and will have the ability to mount forward or rear of the trailer as I'll have a receiver front and rear both. It's the 3-axis design and should work great for both on and off-road use. Very well built. Very nice setup. I got it from the Lock-N-Roll site direct here:
http://www.locknroll.com/index.aspx
and used the #303 adjustable drop/rise bar hitch here:
http://www.locknroll.com/products_sub.aspx?cid=2&id=26
and the #212 2" slide in coupler here:
http://www.locknroll.com/products_sub.aspx?cid=1&id=28
For tires and rims, I'll be running the matching Jeep Moab rims and matching tires. I found a great deal on some matching Moabs here in Washington State. The tires are shot, but I'll use them for now to take measurements from to get the trailer started and get a roller going, then buy tires later when I'm further along. Final tire size will be 255/85/16. Here's the factory Moabs with the stock 245/75/16 MT/R's:
more to come...
Best of Luck,
Mike
![axleparts032.jpg](http://s44.photobucket.com/albums/f47/55willystruck/trailer%20build/axleparts032.jpg)
![axleparts034.jpg](http://s44.photobucket.com/albums/f47/55willystruck/trailer%20build/axleparts034.jpg)
![axleparts030.jpg](http://s44.photobucket.com/albums/f47/55willystruck/trailer%20build/axleparts030.jpg)
more to come...
Best of Luck,
Mike
