Troop Carrier for USA is a GL320 CDI!!
haven
With tongue firmly placed in cheek, let me propose that since Toyota doesn't import the Troop Carrier to USA, we should construct a pop-up expedition camper using the new diesel-powered Mercedes GL 320 CDI.
Since Scott is finished with his Taco, converting the GL 320 CDI would make a great project. I'm sure Mercedes will be eager to provide a donor vehicle.
Here's the tale of the tape:
Toyota Land Cruiser..........Mercedes GL320 CDI
HDJ78R Troop Carrier.........w/ Off Road Package
199..........length..........200 in
125.........wheelbase..........121 in
58..........front track..........65 in
66.5.........width..........75.5 in
83..........height..........75.5 in
9.25 in...Ground clearance...12 in
44 ft.....turning circle.....40 ft
??........max cargo volume...83 cu ft (w/ seats in place)
turbodiesel...engine.......turbodiesel
4164......Displacement....3200 cc
167..........HP..........224
280........Torque..........375
15......estimated MPG.......24
47.........Fuel Tank........26
7.50R16.......tires......265/60 R18
4 wheel disc.....Brakes....4 wheel disc
5speed manual...Transmission....7speed auto
Limited Slip....Differential...Electronic traction control
Part time..........4WD..........Full time
Dual range.....Transfer case......Dual Range
front and rear...Locking diffs ....Center and rear
4993.......Curb Weight......5250 lbs
7055..........GVWR.......... ?? lbs
2060..........Cargo capacity... ?? lbs
440..........Max roof load... ?? lbs
7716.......Max towing.......7500 lbs
82........max load length.... ?? in
59.5......max load width .... ?? in
50........max load height ... ?? in
Mercedes has not released GVWR values so far.
The primary dimension where the Troopie exceeds the GL320 is in interior height. So when installing a pop-up top, we'd have to add a raised roof too.
While the Troopie uses ox-cart springs and simple locking differentials to provide traction, the GL320 uses modern electronics and air suspension.
The GL320The standard GL320 CDI includes a variety of traction aids:
..downhill speed regulation
..Anti-lock braking system
..4 wheel traction system
..electronic stability program
..off-road driving profile
The $2250 Off Road package adds:
..Center and Rear locking differentials
..Adaptive Damping System
..skid plate protection
..Air suspension with up to 12 inches of ground clearance
..19 or 20 inch wheels with more aggressive M+S rated tires
..e.g., Dunlop Grandtrek MT2
What do you say, Scott???
Chip Haven
haven
photos
Here's a typical pop-top Troopie camper
and here's the Mercedes GL 320 CDI
Just remove the Mercedes interior, insert camping gear, and add a pop-up roof. Voila, an expedition camper!
Mercedes does plan to sell the GL series worldwide, so service will be available in many areas. The 3.2L CDI engine is the one they're putting in the Sprinter van, so parts should not be a problem.
Chip Haven
Scott Brady
Founder
Hey Chip,
As always, you are the master at finding the new/cool stuff.
While the GL is a very classy SUV, it could never make it into the Scotty garage.
I am just too much of a functionalist.
Sure would make a great family transport though... :smiley_drive:
Scott Brady
Founder
If I could have either the white Troopy, or a fully loaded GL, I would take the keys to the LC Troopy any day, even if it were worth half the value (assuming I could register it in Prescott:costumed-smiley-007 )
upcruiser
Perpetual Transient
That there troopy is my dream truck.
I've seen some legalized 70 series in the US. I never understood how they got them registered here. Is it even possible to federalize a troopy? If so, what would it take?
Desertdude
Hope you don't mind posting these in your thread - I found this while searching for a camping spot up in Inuvik NWT - it was about 1 AM otherwise I would have engaged with the owner
Brian894x4
Is PV Cruisers based out of Canada or the USA? I link to their site at their request a while ago, but I just assumed they were one of several Canadian importers that are able to bring in Cruisers and 4 door Hiluxes over from Japan that are more than 15 years old. Which of course, aren't legal in the USA unfortunately...technically.
If they got USA registered 70 series Land Cruisers, I may have to sell a Kidney or two see about getting one. :drool:
Edit: Oops, I see that they are in fact USA based and have one Canadian BJ70 for sale. Interesting...but I think i hold out for a troopie....after I win the lottery..hee, hee.
surfponto
There is a real informative thread regarding importing over at ih8Mud.
Good reading if you are remotely interested in a diesel LandCruiser.
http://forum.ih8mud.com/showthread.php?t=10164
Bob
ChuckB
I have seen a troopie on the road in California of all places, I almost seperated my head from my neck as I watched it go by in the oncoming lane.
I'm keeping an eye on PV cruisers. I may have to make a binge purchase... I believe the owner has posted on 'mud a few times.
SANelson
