Truck Bed - Flatbed Swap
Crosley623
Well finally getting started on my winter project of custom flatbed camper build. Just picked up a 23 Chevy 2500HD. It’s the short bed model and I’ve found an aluminum flatbed to buy. Flatbed is 90w x 96 long. Should be perfect but I may trim the width down.
Hopefully get started this week but wanted to ask about the swap for advice on swapping the wiring.
Trailer - will be easy to swap out and mount near the hitch.
Reverse Sensors - hoping that it’s as easy as promising and mounting in holes on the skirt of the flatbed.
Brake Lights - should be easy swap
Rear Camera - just remove for now. Buy an aftermarket camera to install in the camper framing and be able to splice into the factory wiring?
Any info or advice would be awesome!
Its possible that the tailights are more complex than just hooking up to a new fleet truck light like you will have on a flatbed. I had to join two separate wires (one for running, one for brake) into a single LED. That required an inexpensive diode to be added.
There are lots of aftermarket cameras available online. there are a few different video codecs, most cameras support two, and you change the code by cutting a jumper wire. I bought a couple of cameras that were incompatible with my rear view mirror screen. There are also different connectors and connector set ups. Some send video along a dedicated RCA cable, some have a small 4 pin connector some have 5 pin, and even if the connector is correct, I've had a camera with different pinouts.
Thanks for the info. Of course it won’t be as easy as I expect!!!
MOLLYmaz
