Truckfridge fridge/freezer sale
1Louder
With that said, I don't trust the ArkPac's electronics to handle the fridge, while using its DC charger. So, I'll be hooking up a CTEK 250S Dual to charge the Aux Battery, while on the road. Eventually, there will be a solar panel connected to the CTEK as well.
Slightly off topic but yes I think I have seen the same issue with trying to leave the fridge plugged into the ArkPak and charging it at the same time. Good thing is my truck has two 12 volt plugs which I installed so I can run the fridge and charge the ArkPak at the same time. This week I am going to convert one of my 12v plugs to an SAE connector and install that into my truck. I just think it will be a way more secure connection.
1Louder
My FJ had a dedicated 12 volt plug for my fridge but I always hated the connection. So today I converted it to an SAE plug. Really easy to do. You can either cut a cord and wire it up or use the ARB plug listed below and just use blade connections with it. I will clean it up when it cools down a bit with some heat shrink tubing. I have already changed the silver screws with black ones for a cleaner look. I already had the on/off switch installed and it still works with the SAE plug.
Required parts:
http://www.sierraexpeditions.com/index.php?l=product_detail&p=2292
CES 12 Gauge 2 Pin Quick Disconnect Harness
by CES
Link: https://amzn.com/B006ZOGYUU
http://www.ebay.com/itm/391399826815?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Joseph McCormack
