crawler#976
We're heading out in June for a 15 or 16 day vacation to the Northwest via the Oregon Coast to the Seattle area. With gas prices climbing, I've "de-modded" the Taco attempting to regain a few MPG. I estimate the trip to be about 4500 miles long.
Started checking mileage a few months ago- it had averaged 16.3 MPG. I don't do jack rabbit starts from lights, nor do I speed, and I use cruise control whenever possible. The fuel cost at 16.3 MPG is roughly $1035.00 @ $3.75 a gallon. If I can pick up 2.5 MPG, it drops to $897.00.
Wind resistance -
I've already removed the roof rack - picked up almost 1.0 MPG
Removing the rack ment the spare had to be relocated under the bed, so I had to have the custom exhaust rerouted. The hi-lift and shovel were moved to the inside of the tailgate - don't know where to put the spare gas yet...
Tires -
When I put on the new 31/10.5-15 MT/R's the MPG dropped almost 1.6 MPG. I've purchased a used stock alloy rim from an auto recycler, and by using my new A/T spare and buying a new tire to match, hope to get half that 1.6 MPG back. I'll run the A/T's up front. They won't be mounted until the week prior to our departure when I get the front MT/R's balanced and rotated to the rear. I plan on running the air pressure at 35 PSI vs the current 28 to firm up the tires a little.
Fluids -
Drained and refilled rear axle and transfercase with synthetic 75/90W.
Had the tranny fluid exchanged to remove all the old fluid vs just a drail and refill. Will be switching to synthetic 5/30 motor oil jsut prior to leaving.
The K&N airfilter has been cleaned and lightly oiled.
I've also plan to wash and wax the truck prior to leaving to improve airflow - maybe it will help, maybe not...
Any other tips/hint's???
Mark
Wind resistance -
Tires -
Fluids -
Mark
