Universal RAM Pod 3 Vehicle Base with RAM-B-202U Mounting Plate
Just bought this from www.themountdepot.com for $102.95. I started to set it up in the Montero but then decided to fabricate a custom mount myself. The pliable poles were scratched in the process and I used a black sharpie to mark where I wanted the bends. The poles are covered by a black flex tube so it doesn't show anyway but it still prevents me from sending it back.
$75.00 shipped to you!
wesel123
Hey Bjorn,
Are the lengths of the arms adjustable??? Might be interested if I can figure lengths for the LC.
thanks
Ian
Hi Ian,
Length of Leg 1: 18''
Length of Leg 2: 20''
Length of Leg 3: 30''
The legs are made of a bendable metal (aluminum?) that is pretty soft but still holds weight. Does that make sense? You can easily cut them to fit your application. That is what the instructions say.
I was going to install them with the two longer ones on the seat base of the passenger seat and then mount the other leg somewhere to give it support. When I took my radio out to put the new one in I discovered a new mounting spot and won't have to use this mount after all.
$60 shipped!
Replaced the 6" arm with a 9" arm. Used the 6" arm on my Montero project as the length was better for me. This is a great deal! I need it gone. Shoot me an offer folks!
Clemtiger84
