URD Group Buy, 3.4L 5VZ-FE Crank Shaft Pulley
SAR_Squid79
Some guys on Custom Tacos got a Group Buy together for a run of the URD Crank Shaft Pullies. Gadget says that this will be the last EVER run of these Crank Pullies. This is one of the things I've had on my to-do list FOREVER, and never got around to it. So if you're like me - this will be your last chance! I pre-ordered mine yesterday.
The pullies are marked down from $300 to $250 for this group buy.
Product Info:
This pulley has been out of production for a while. After numerous requests from our customers URD has decided to make another run of these crank pulleys. The expected in stock date is September 9th. For those people that would like to preorder a pulley before they are ready to ship, URD will offer you a significant discount. Once they start shipping the regular price will go back into effect. Over the life of this product there have been decreasing demand for it, and this may be the last run of these pulleys URD does. If you want one, you may not get another chance.
For this run the pulley will be slightly different in than what is in the pictures. On the belt drive closest to the engine we will not have the slits cut into the pulley. We are doing this to reduce the cost to you.
URD made a lightweight crankshaft pulley for a desert race team truck powered by a supercharged 5VZ-FE. They wanted to squeeze out every last bit of acceleration horsepower from their race engine.
The stock crankshaft pulley on this engine weighs ten (10) pounds. Our end product weighs just 2 pounds 10 oz. That means the stock pulley weighs 385% more than ours. There are a few Internet sources that claim for every pound reduced in rotational mass of the crankshaft assembly, you gain 2.7 acceleration horsepower.
  • Aircraft 6061 T-6 billet aluminum
  • CNC machined to .001" tolerances
  • Bolt holes designed for OEM crankshaft tools
  • MILSPEC grade hard anodized
  • Over 7lb weight reduction frees acceleration horsepower and torque
  • Snappier throttle response
  • Stock belt drive diameters
If you want the last bit of power out of your 5vz, then this pulley may be for you!
Pre-Order Here:
http://www.urdusa.com/product_info.php?cPath=102_109&products_id=1230100021
Here's the link to the group buy on Custom Tacos:
http://www.customtacos.com/forum/showthread.php?t=135811
dhuss
