4671 Hybrid
I have a few extra of these bags after buying some for family and friends. They are used but in Excellent condition and priced to move at the cheapest price in the country at $70. I'm guessing shipping should be between $15-$17 so no more than $85-87 shipped to anywhere in the US.
DETAILS:
Main pack for USMC developed after experience in Iraq and Afghanistan.
Condition: Excellent.
Perfect BugOut Bag.
Designer: Arcteryx.
Manufacturer: Propper International.
Distributes up to 120 pound load between hips and shoulders.
Internal frame has main spar on either side of center. Two supporting rods extend up the sides.
There are three main elements in the system. 1) Main pack, 2) Lid which incorporates a separate pouch, and 3) hip belt.
This is only for the MAIN PACK.
Very heavily padded hip belt allows full load to be carried on hips, or balanced between hips and shoulder straps in any desired ratio.
Hip belt can be removed for easier transport.
Three compression straps on each side to keep load tight and prevent it from shifting and flopping around.
Main pack opens on top, and can also be accessed from full length zippers on either side. You don't have to dig down from the top to get stuff below.
Main pack can be divided into two internal sections. Divider is rolled up and snapped away when not in use.
Back of main pack has a "carrier" which can hold a CamelBak or smaller pack. For example, it can carry a separate 1,600 cu inch pack.
Rubber wrapped metal carrying handles on each side.
Pouches on bottom carries water bottles, etc.
Panels on sides can securely hold fishing poles, hiking poles, tent poles, etc.
Covered with MOLLE attachment points
Extremely tough and well built. Made for the roughest treatment everyday over extended time.
Cordura 720 denier fabric.
4,500 cubic inches in main pack. Compression straps keep it tight on amy sized load.
Designed to handle 120 pounds.
Zippered access to main pack on both sides.
Zippered pouch incorporated in lid. Lid is removable.
Adjustable shoulder and chest straps.
Heavily padded hip belt.
DETAILS:
Perfect BugOut Bag.
Designer: Arcteryx.
