grunt outdoors
Asking $14,000.00 OBO - Located in Northern VA
gruntoutdoors20@gmail.com
It’s been an amazing couple of years with the Vagabond Outdoors The Drifter but it’s time for change.
This Drifter is for a Gen 3 Short Bed Tacoma. I’m not sure what other vehicles it might fit. If you want to be able to wheel hard while carrying your house, it gets no better than The Drifter. I wheeled with The Drifter on Hell’s Gate, Engineer Pass, Fins and Things, Crawl Daddy, Dickey Bell, Tread Lightly, etc… The Drifter can handle anything you can throw at it. It has normal wear but everything is in working condition with no leaks.
From the factory: All Aluminum Construction, One-piece Lid Design, Insulated Ceiling, Concealed Lift Struts, Waterproof Tent w/ 3 Windows, LED 3rd Brake Light & Wiring, Glass Cab Window w/Drop Down For Cleaning, Rear Glass Window w/Keyed Locks (3), 1 Lower Interior LED 10″ Light Bar (White & Orange) with Dimmer Switch, Concealed Wire Tray, Adjustable & Lockable Stainless Steel Latches, Camper Attachment Clamps & Bulb Seal Gasket, Lower Level Lighting, Interior Ceiling Light, 14” Maxxair Low Profile Fan - Reversible 4-Speed, 96” L-Track Roof Mounts, Side Insulation w/Paneling, Canvas Works Winter Insulation Package
Aftermarket: Alu-Cab Shadow Awning (Driver Side), Alu-Cab Shower Cube, Go Rhino Gear Plate Kit, Go Rhino Reel Handle, JE Design Drip Rails, JE Design Step, Exped Megamat with hand pump & widget pump, Powerwerx USB QC3.0 and USB Type-C QC4.0 Fast Device Charger, Powerwerx Cigarette Lighter Socket Automotive Marine Grade outside by the Alu-Cab Shower Cube, Plexiglass Rear Window, Interior L-Tracks, Strawfoot Rear Hatch Window Cover (needs adhesive steel strips), Strawfoot Fan Cover, Overland Vehicle System Organizer, Water Proof / Dust Proof 3” Port for Diesel Heater or AC connection, Traction Boards, 1 5 Gallon Fuel Container + Lock Mounts.
What’s not included: Taco, Hest products, Sleeping Bag, Jeep Badge Of Honor Badges, Interior Build Out (refrigerator, power solution, storage solution, and Auxbeam), Storage Bag.
