part time nomad
I have been considering air conditioning for my Vario
does anyone know if there is a standard fitment option ?
I am considering a similar idea, I have a Dometic HB2500 its an under locker type unit (currently fitted in my caravan)
Its not as powerful as in dash vehicle fitted types, so I am looking at options!
These Dometic units run best on pure sine inverters, and I have heard quite a few reports of them trashing inverters after time.
Strangely enough Dometic do an inverter that is suited to them but you are looking at £1000
I'm thinking of just installing this above the cab:http://www.dometic.co.uk/product/dometic-freshjet-1100/
Just going to run it off an inverter, Shouldn't pull more than ~35-40A, my battery to battery charger can allegedly go to 50A, so should all work out. Much easier and probably cheaper than retro fit of a dash variant, take us no internal space, and there is already a roof light cut out area thing above the vario cabs. This is all for a panel van version though!
Yea I think the application of these roof top ones is pretty limited. I have a separate cab to the living space, and would use it only to cool the cab when driving. Have a regular air con unit for the living space.
