VIAIR Onboard Air System GROUP BUY
RocKrawler
Supporting Sponsor
Here are your tracking numbers, the kits shipped out 6/24/2010:
SLAVERBRO (FJCruiserforums) - Super Duty Package (20001)
FedEx Tracking Number: 409835760206327
TREVPIEE (ExPo) - Constant Duty Package (10007)
FedEx Tracking Number: 409835760206389
DARINM (ExPo) - Heavy Duty System (10005)
FedEx Tracking Number: 409835760206426
BIERE (ExPo) - Constant Duty Package (10007)
FedEx Tracking Number: 409835760206372
RufusTheDufus (IH8MUD) - Super Duty Package (20001)
FedEx Tracking Number: 409835760206341
BROMO95 (IH8MUD) - Constant Duty Package (10007)
FedEx Tracking Number: 409835760206365
Coldnapalm (FJCruiserforums) - Constant Duty Package (10007)
FedEx Tracking Number: 409835760206396, 409835760206402
Fireman78 (ExPo) - Super Duty Package (20001)
FedEx Tracking Number: 409835760206334
OYAJI_JON (IH8MUD) - Super Duty Package (20001)
FedEx Tracking Number: 409835760206310
kjswiley (ExPo) - Constant Duty Package (10007)
FedEx Tracking Number: 409835760206358
Medic (FJCruiserforums) - Super Duty Package (20001)
FedEx Tracking Number: 409835760206303
Rosenfeld (Walkin) - Super Duty Package (20001)
Picking up at shop
Fogblanket (IH8MUD) - Heavy Duty System (10005)
FedEx Tracking Number: 409835760206419
Thanks to everyone for your participation and enjoy your new onboard air system!
10005 Reg. $369.95 VIAIR Heavy Duty Onboard Air System
  • 12-Volt
  • Permanent Magnetic Motor
  • Duty Cycle: 33% @ 100 PSI
  • Max. Working Pressure: 150 PSI
  • Max. Amp Draw: 26 Amps
  • 1/4" NPT Intake Port
10007 Reg. $399.95 VIAIR Constant Duty Onboard Air System
  • 12-Volt
  • Duty Cycle: 100% @ 100 PSI
  • Max. Amp Draw: 19 Amps
10008 Reg. $489.95 VIAIR Super Duty Onboard Air System
  • 12-Volt
  • Max. Amp Draw: 35 Amps
10009 Reg. $549.95 VIAIR Extreme Duty Onboard Air System
  • 12-Volt
  • Max. Amp Draw: 29 Amps
20001 Reg. $469.95 VIAIR Super Duty Onboard Air System
  • 12-Volt
  • Max. Working Pressure: 200 PSI
  • Max. Amp Draw: 20 Amps
  • 3/8" NPT Intake Port
wanderer-rrorc
I already have one...but its worth EVERY PENNY!!....I put a bigger tank in for mine (we used it alot in the pits.)..
that is all..enjoy!
RocKrawler
Supporting Sponsor
Great experience - yes you can always upgrade the tank size, but you can also always add a second small tank for added volume, sometimes its easier to fit 2 - 2.5gal tanks than one 5 gal and the result is the same.
ExpoMike
Can this be bought with a smaller tank? The location I am thinking about won't have a lot of space and I think the 1 gallon tank would work better for me. I am also only filling 31" tires.
PM me if you can do a smaller tank and pricing shipped to 92126 area.
RocKrawler
Supporting Sponsor
I'll check for you on Monday when I get back into the office - I'm sure I can build you a setup that will fit your needs.
Clemtiger84
