VW Syncro Westfalia 1990. $36k
Ranchero
Wanderer
Volkswagen Westy Syncro 4x4. 224,500 miles $36,000
  • This is a solid camper. Drives very well. 4x4 works great. Paint is glossy. It looks great from 10 feet but is not a garage queen. It has some of the typical Vanagon seam rust (but minor) that has been repaired. Utility inlet metal has been repaired. Rock chips on front valence, etc. Has the typical Vanagon sliding door dent. I bought this in 2007 and have been all over the Western US and Canada in it. I would drive it anywhere without worry. $36,000. This is priced at the lower end of the Syncro Westy market. You could buy this, drive it a few years, then likely sell it for more than you paid for it. Will deliver anywhere in lower 48 or Canada for a plane ticket back. I' m not eager to sell, but marital bliss might level up if I do.
Powertrain
  • Subraru 2.5l purchased from Mastercraft/Hatfield in Santa Barbara. Installed in 2008 and has about motor has 90k miles now, with 30k by me. Headgaskets replaced preemptively at install. Top quality swap parts used: SmallCar, Burley Motorsports, Mastercraft, Tom Shiels. Everything important replaced at install: radiator, stainless coolant lines, all rubber bits, clutch, and slave cylinder, stainless exhaust
  • Transaxle rebuilt about 60k miles ago. 025 Motorsports 711 shifter. Viscous coupler is working fine.
  • Front differential rebuilt about 20k miles ago
  • New driveshaft about 20k
  • Rear locking differential and decoupler. (Decoupler allows shift from 4WD to RWD on the fly)
  • AC is not installed but a working compressor, condenser, and all lines are included.
Brakes/suspension/body
  • Brakes updated to larger front rotors and calipers (Audi S6)
  • Rear brakes converted to disc with GoWesty kit. Uses VW/Audi calipers and rotors Brakes work fantastic!
  • Toyo Open Country tires 225/70R16 (5) with less than 1000 miles mounted to CLK forged aluminum wheels.
  • Schwenk lift springs (2023)
  • Bilstein B6 shocks with 16" Syncro dampening (2023)
  • All suspension bushings have been replaced with combo of rubber and poly.
  • Rocky Mountain Westy bumpers
  • South African grille with Hella halogens.
Camper stuff
  • 100ah LifePo4 house battery
  • Renogy DC to DC converter (manages charging. Alternator and solar can charge both the house and starting batteries.
  • 100A solar panel
  • Built-in 120v charger
  • Vitrifrigo 12v/120v refrigerator
  • Propex propane heater
  • Fresh carpet
  • Both factory Westy tables
  • Fiamma awning
  • Screens for sliding and rear doors
  • Canvas, curtains, and upholstery in good shape
  • Driver and passenger windows converted to manual crank with factory door panels in the correct grey color. Have original electric ones and clean door panels for those as well
Spares of note
  • Four fully rebuilt axles (new 944 CVs and boots), two new Burley Motorsports bearing housings with new bearings, fuel pump, filters, rubber bits, two VC cores, etc.
Trades (full/partial) considered
HZJ75 troopy, FJ75 Troopy, or Tundra. Maybe newer Husky or KTM 350,500,890.
Ranchero
Wanderer
Forgot to mention that I have insulated covers for all windows and pop-top. Winter camping is toasty with those and the Propex propane heater. If you don't know the Propex, all combustion occurs outside the vehicle so there is no condensation and they are perfectly safe. Aftermarket defroster for wiper parking area is installed - I used to ski a lot all over the Rockies.
Petersmithinak
