VanWaLife
So just kind of spitballing here...pretty bummed that freezing temps can destroy the Roadshower. I've given some thought to solving this problem, and have a two-pronged approach in mind: attach a 12v electric heat pad to the Roadshower, and sew up an insulated cover for it.
As far as the heat pad goes, this is what I'm looking at:
As far as the cover goes, I don't have any sewing skills. But basically I'm thinking a big tube shaped cover with a slit all the way down one long side, with velcro on either side of the slit. There would be a few velcro closure pieces to go between crossbars. Possibly holes with velcro flaps for the fill and charging ports. As far as cover material, I'm thinking space blanket type shell with an inner fabric insulation layer.
I think this is a pretty good idea, probably marketable to a great many Roadshower owners, maybe Yakima. The cover may be enough without the heater for a lot of situations, not sure how well the heater would work in lower temps.
So if you got sewing skills, especially in the PNW, let me know if this is a project you want to take on. I just want a cover, don't have any interest in commercialization of the idea myself.
If you have a Roadshower and also have considered this problem, let us know what your thoughts are, and what you think of this idea, and whether you'd be in the market for an insulated cover for your Roadshower.
Silicone Rubber Heater, 1" x 1", 12V, 5W, 6" leads
Silicone Rubber Heater, 1" x 1", 12V, 5W, 6" leads, available for online ordering from O.E.M. Heaters.
www.oemheaters.com
