Wanted: Yakima LowRider mounts or 1A Rain Gutter Mounts
stick
I'm looking for a set (4) of the Yakima Low Rider (must be the newer style that clamps on) or 1A Rain Gutter Mounts. Let me know what you have and how much.
Edit: I also need 66" or larger cross bars.
Thanks
UPDATE: I found some mounts, but still need some cross bars.
Mike S
Sponsor - AutoHomeUSA
LB58 load bars
I believe that I have a new set of Thule LB58 load bars in the shop. Call if interested - 888-852-2359 8AM to 5PM, M-F
Mike S
stick
John, those might fit the rails on the M416, but I'm not sure how I could mount the round Yakima bars to them. I'll have to look into that a little more. Square Thule bars would probably work, but I was hoping to stick with Yakima since some of my Yakima bike racks only mount to round bars. I'd like to keep the bars and accessories mounted on top of my XJ compatible with the bars and mounts I use on the M416. Thanks for the heads-up though. Let me know if you stumble across anything else. Are you still looking for those 2 Thule mounts?
Mike, thanks for the offer, but I think I'd like to stick with round Yakima bars if possible. I'll give you a call if I can't find anything else.
OverlandZJ
OK, didnt realize you had gear you needed to keep transferable, makes sense.
No, i picked up 4 more Thule 300 towers, now have total of 4 loadbars under the RTT.
stick
I found some mounts, but still need some longer cross bars. Upon a closser look, the 66" or longer bars would work best.
stick
Nullifier said:
I some of each I can sell. How many of each do you need?
What do you have? I have some LowRider mounts coming in the mail, so hopefully that will work for me. I basically just need some 66" or longer cross bars now.
Goldenbora
