flyingwil
Any one see one of the new Warn PowerPlants yet? :drool:
With a flip of the activator switch to compressor mode it puts out 5 cfm @ 90 psi, with a built-in air reservoir and intercooler. Switch to winch mode and the pulling power of the Gen II Series Wound motor with the 3-stage planetary gear train.
The only downfall is having the 100lb sucker forward of your front axles.
Seems like an awesome idea to combine a compressor and a winch. For the guys not driving a Jeep or simialar syling it might be hard to mount or find a bumper suitable for mounting...
What do you think?
- 12 CFM @ 0 psi, 5 CFM @ 90 psi air flow rating
- 100 psi max air pressure
- 9,500 lbs. maximum rated pull (single line)
- Line speed of 26.9 feet minute (no load),
- 5.2 feet per minute (at 9,500 lbs. max load)
- 125 feet of 5/16" wire rope
What do you think?
