Chorky
Ok so question for you all. There undoubtedly is a lot of discussion on water heating types. Propane, diesel, solar bags, etc...
Though I am still trying to figure out needed battery bank size for a variety of things, and what this means in terms of battery size, type, recharge rate, etc....
A current plan has me installing a 30 gal water tank, 5-10gal water heater (heat exchange unit) with a diesel heater - in one of the boxes of a flatbed. This way fresh hot (and cold) water is at the ready regardless of a camper being present. Hey, sometimes when you're just cutting trees you still need a quick bath, or to wash off and clean that steelhead you just caught with the first home made fly!
Ok so, the question regards water tanks. There is a lot of discussion here about the diesel heaters, and the electrical side, but I have searched and find very little regarding tanks.
What sort of tank set-ups are out there, pros/cons, all things associated with them? There are different theories I notice. Some plumb into the vehicles coolant system. Some have a dedicated coolant box just for a heat exchanger for the water tank/interior heat, etc... I'm looking for some reading material on this since I really don't understand a good way to do a hot water tank, how it would hook up, what size it should be, or where to even source one quite honestly.
Looking forward to the communities input!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
