webasto, Eberspächer, water heaters, which one to get?
Standard muffler on the Webasto, it's the grey think on under the silver radiator.
attachment.php
I use Espar for heating in m y TC,very efficient and low power consumption..didnt know that one can heat drinking water with these???
I have been thinking of this for my build. Using a heat exchanger for a shower. One side plumbed to the heater and one to the on board water tank. I would also have a switching valve to divert heater flow to a radiator for cabin heat.
Pretty common over here in Australia
http://www.glind.com.au/
Make you you get a thermostatic mixing valve, the first blast of 85 Dec C water could really ruin your day.
http://www.isotherm-parts.com/spa-line-water-heaters-c-4_34_107/
As Ian says nothing new here, these systems have been around in the boating world for decades. They work very well and diesel engines are a great source of free heat.
Ian, your muffler looks similar to mine, (mine is not a webasto muffler). Without the muffler it sounds like the airport!
I suppose having the electric heat option would be nice too but does anyone make one without the electric heater element?
Search Google, I don't think the electric element can add much to the cost and it is a nice option if you stay put for more than a day or so. Of course you can heat the water with your Webasto/Esparcher as well.
What size tank do you run? How fast does it recover if you use all the hot water?
The one I posted in #12 got the option, type ME.... you can get one without the electrical too, type M, see link in post.
The Spa 20, 5gal. That's enough for 2 showers, we only run out of hot water if we do a load of laundry. I have not noted recovery time but after driving (1hour) there is always hot water.
Ok good info.. Thanks! I think the 5 gal Spa would be ideal and the electric option is a nice bonus. Do you heat your cabin with the espar? Mine will be pretty small so I was thinking that a small liquid to air heat exchanger would work well to just radiate heat into the cabin
5mouse
