What recovery tools would you never go without?
Seems like you're set for back roads exploration. Max trax would be good for muddy roads. The thing about having a hi-lift is that unless your rig is setup to be raised by a hi-lift, its pretty much useless. A winch would be a good addition, but that's about it. You should take your local weather and environment in mind though when going exploring. Definitely take a phone with you, or radio, depending on reception.
If comes to just Recovery- Shovel, Snatch strap
If you want to a add to keep it going/running that's a whole different area. In a way I guess you can lump that into recovery.
-Some Basic Tools
-Emergency repair tape
-Heavy gauge fencing wire, and pliers
-Jumper leads
-Some sort of emergency repair epoxy stuff.
-Really good cable ties
-Plenty of water for a coolant leak, just keep pouring it in till help.
-Plenty of oil for a an oil leak, just keep pouring it in till help.
-Be a lateral thinker with mechanical/electrical aptitude.
-If all else fails, communications of some kind to get help.
Had no winch on a pickup I owned for at least 10 years. No limited slip or locking diffs either... Of course, I got it stuck... While I was alone, up on a remote dirt road. The snatch strap was useless without another vehicle.
The hi-lift jack and shovel, and a long workout session, saved the day. Jacked the truck up enough to build up rocks underneath the front tire. A bottle jack wouldn't have worked. No where to put it, but the 60" hi-lift earned it's keep that day. One of the few times in 20+ years of owning it that the doggone thing actually came in handy.
Shovel & hi-lift are important. And... Save up for a winch. Decent ones aren't all that expensive anymore. I've got one on my Jeep now. The winch and good tires were the first things I did to the new Jeep a couple of years ago.
Regards, CW
The title kind of speaks for itself! I am trying to put together a roof basket or cargo box that I can easily transfer from vehicle to vehicle when I go out. The question is what do I need to carry. Im looking for some insight from experienced guys like you, to see what you actually use and what is pointless extra weight.
It would be for:
2008 toyota tundra (5000lbs+)
1959 willys wagon (under 5k)
I have no winch on either vehicle and I am currently running stock bumpers on the tundra. The wagon has steel round tube bumpers front and rear. Both have heavy duty receiver hitches.
I plan on using a long rectangular basket (7'x2') from rhino rack so I can still have room for kayaks or the canoe up top.
What do you think?
A few sticks of dynamite, and everything ARB makes... duh
Regards, CW
You can even bypass the winch if you must with a highlift as long as you have the top tooth. I would hook to it with a shackle through the hole in it though.
I've only tried to use the high-lift jack to raise the vehicle on two occasions. I learned that its dandy if the task is to lift the vehicle so that it moves to one side, 'cause thats what happened : Got jacked up to about 2/3 height on the jack then the whole vehicle leaned over. To change a tire, a bottle jack is a better tool.
You have to be careful about HOW you use them. Probably an unseen factor or improper placement. I like to use an axle strap wrapped around something to lift from. If using it on a tire I wrap the strap right around a spoke. Once the tire is off the ground I stuff a jack stand under it
Wolfbox
