What sort of shell/top for 05+?
gearbox
I thought I had decided on an ARE CX but I've witnessed a disappointing gap on another truck. I hear that SnugTop and Leer both seal out water better. As an expo truck it would serve to shelter recovery gear, a compressor, bedding, an inverter, and a bunch of "assorted stuff". Corrosion and mildew would be a most unpleasant surprise.
I'm looking for a cab-high with rack tracks, sliding flip-open side windows, and flip-down front window. I'm middle class: price is an object.
I personaly think the ARE are better built caps then Leer IMO. The gap you might have seen on the ARE might have been a bad install. People have the same complaints about Leer too, only to find it was installed wrong. It's all about the install.
I have a Leer by the way.
not to hijack but on a similar note, how are the tops attached to the bed? i doesn't look as though the typical under rail mounts would work. thanks
jake
jake
You can see the mounting on the left in the rail.
heeltoe989
I have a leer, when the company did the install it leaked, when I took it off and got some foam tape and place it around the bed of the truck, it didn't leak. Poor Install like most companies around here.
I like my leer and has worked great so far.
Leer 100R canopy w/ windoors, lined, front slider/pop out window, cargo light, overhead storage bin, color matched
Overland Hadley
on a journey
I like my Leer, although it does leak a little water. It is very strong and solid. I ordered mine with Thule top tracks from the factory, and so they built it with a honey comb roof to support the weight. I could stand up there no problem.
OTR
I have a snugtop on my Tundra and am very happy with it. I installed my Yakima landing pads last weekend on the top. I was very impressed on how sturdy the roof was while I was walking on it (I weigh 200 lbs) with no sagging at all. If you aren't in a hurry, watch craigslist for a used top and save a ton of money. I would even contact people with a truck w/cap for sale and ask if they are interested in selling the cap only.
barlowrs
I have the bestop soft top. and I love it! I can sleep in the back, and it stays pretty warm. (Have slept in it while ice climbing.). On hot climbing trips in Josha Tree, I can take all the windows out so i still have a roof and shade, but still let a breeze get through. And i can collapse the whole thing when i need to take my motorcycle to the track or haul large things.
rambrush
I am running the GemTop Workmaster on my 06 Tundra with the 4x4 package to make it beefy. open up the side compartments for easy access to the side shelves. big stuff goes in back. Not the prettiest but its tough.
Martinjmpr
Wiffleball Batter
I've owned probably half a dozen shells over the last 20 years, including a Leer, a couple of Ravens, an old Glasstite, a polycarbonate (stay away!) and even an aluminum cheapo on my old Mazda B2000.
The one thing I like about the Leer shells is that IMO their attachment system is superior to any other one I've seen. Most shells use C-Clamps to clamp the rail of the shell onto the bed rail. Effective but the C-Clamps are big and crude and intrude into the usable cargo space. The Leer's use a different system, which you can see in Streakerfreak's pictures: The bed rail has a reinforced hole in it, and a bolt drops through that hole into a small "j-clamp" that clamps to the underside of the bed rail to lock the shell down. Nice thing about it is that it doesn't intrude into the cargo area of the shell. It's also a breeze to remove, which you can do with a single ratchet (as opposed to the C-clams where you have to loosen the bolt with one hand and hold the c-clamp with your other hand to keep it from flopping around.)
Other than the attachment system, I wasn't all that impressed with my Leer, though to be honest I was at least the 3rd owner of that shell and it was still intact, so there's something to be said about that.
As a total, complete cheapskate it is very difficult for me to consider buying a brand new shell (where $1,000 is the base price of a decent fiberglass cab-high - that's before you start adding the goodies like drop-down front windows and side wind-doors) when you can pick up a used shell in great condition on CL for under $500. Toyota Tacomas and Ford Rangers are the most common compact trucks around so finding shells for them is relatively easy. And you'd be amazed at how many people buy a truck with a shell and remove the shell, only to leave it sitting in their yard for months/years, and who are willing to sell it for next to nothing.
But it really just comes down to whether you want to get the exact features you need - in that case you'll have to bite the bullet and pay full price (but be ready for a shock. Off hand I'd imagine a nice shell with the features you want will cost you close to $2k.)
This high-top shell (I think it's a Raven because the design is very similar to a Raven I had years ago) cost me $300 on CL and the only thing wrong with it is that it didn't have any keys.
I simply removed the lock from the door (took me 10 minutes), took it to a local locksmith and they made me two keys for about $15. It has the carpeted liner, too, which is nice because it will allow me to attach blackout curtains with just velcro "hook" tape on the corners.
By the way, it took me about 2 weeks to find this shell on CL last Summer (in Denver.) The only reason it took me that long was because I specifically wanted a high-rise (I had a cab high and didn't like it for camping.) If I'd wanted a cab-high it would have taken me a matter of days to find one.
flipstick
