Where to find RV solar power parts in Baja Mexico?!
beneng_jr
Currently traveling through Baja, didn't have time to do a shakedown of my solar system in the desert before going on this trip and just realized (1) I need a larger solar panel, and (2) I have a smart alternator which means my dc-dc charger doesn't put out power most of the time.
Be nice to find a place where I can buy a larger panel- I know there are alot of places where I can get panels but seems like its mostly larger ones for homes, any advice on if any RV/Overland specialists in the La Paz/Todos?Cabo areas exists would be rad.
Also could use the IGN cable for Renogy DCC30S (or DCC50S), thought I had a non-smart alternator but turns out I was wrong. Assuming that's a long-shot but could maybe jimmy it by shoving/soldering some wire into it. Don't care if I damage it, its ********* unless anyway, why they gotta bury in the fine print it will only pull 15a from the alternator when it detects any voltage whatsoever from the solar panels?
Pacific Northwest yetti
Expedition Medic
Can you program the DC/DC? Also, try turning on your high beams to see if that ups the voltage, it sometimes works as a stop gap. The Renogy stuff, is eh.
You should also be able to get amazon prime to ship to you, if you have an address that you can use.
Mcoleman
