Where to look for a used Fuso FG140?
I am interested in any links you might have to a FE 4X4 conversion as those do seem reasonable to find.
One notable difference between the FE and FG is that the FG has a stepped chassis. This allows the front to be higher, to give clearance for the diff.
If you lift the front of an FE, you would also have to lower the rear suspension (maybe using spacer blocks on the springs, like on the Isuzu NPS) in order to keep the chassis parallel to the ground.
The front diff on an FG sits pretty much directly under the sump (the sump pan is also different on the FG), but if you were doing a FE conversion, getting a diif where the pumpin was offset more could make the task easier.
Can we import a relatively new super singles Fuso with some upgrades from Canada to the USA? Does the 25 year rule apply here as well?
CL
  • westchester > cars & trucks - by owner
◀ prev next ▶
reply
2001 Mitsubishi Fuso FG 4x4 - $13000 (Katonah NY)
image 1 of 5
1
12345
2001 Mitsubishi fuso Dump truck
fuel: diesel
paint color: red
title status: clean
transmission: manual
Selling my Mitsubishi fuso
It is 4x4 and a 5 speed
66,000 miles on it
It’s a work horse
Dumps drives as it should
New bed floor all new metal plates
New tires
Barely any surface rust on chassis
Please no calls after 9pm
© craigslist - Map data © OpenStreetMap
(google map)
  • it's ok to contact this poster with services or other commercial interests
post id: 7047310861
posted: 21 days ago
updated: 8 days ago
email to friend
♥ best of [?]
Wolfbox
