White vinyl for the roof?
milo12
Does anyone know where to buy a roll of the white vinyl stuff that they stick on new cars?
I am considering putting this on the roof of my truck. I think if the roof was white it would be a lot cooler in the cab. Another issue is, I notice a lot of heat comes through the windshield but I guess I cant do anything about that.
Desert Dan
White roofing paint would probably be better. Use the elastomeric highly reflective type.
I am considering doing that on my TJ's black hard top.
BIGdaddy
your idea is a good one, but will have a less than desired outcome. Paint color has been shown, NOT to effect overall temperature of a vehicle over an extended period.
what you want is a tropical/safari roof a la series land rover. This was basically a skin of aluminum riveted onto raised lengthwise ribs on the
roof structure. This effectively shaded the roof and re-released the stored solar energy(heat) back into the air, rather then re-radiating it into the vehicle.
groovy.
-B
RonL
"Paint color has been shown, NOT to effect overall temperature of a vehicle over an extended period." What do you mean by this? I own two Rovers,one dark green and one is white. The white Rover is 20 degrees cooler(Infrared reading) then the green when sitting in my driveway in the sun.
I think 20 degrees is a big different.
James86004
One of the vehicle testing engineers I talked to here in Arizona told me the vehicle color does not affect the interior temperature as long as the vehicle is moving at 25 mph or more. Given that on dirt roads you are frequently traveling slower than that, color is important.
I found that roofing paint works best, way better than white body paint. It doesn't look as good, but it is way cooler. I found mine at the hardware store - it was advertised as being good for the roofs of mobile homes, RVs, metal outbuildings, etc. I painted the top of my Series Land Rover (one without the tropical roof), and the surface temperature of it was cool. We had a white car at the time, and the roof of the white car would still make you hand uncomfortable on a hot day if you left your hand on for too long. The roof of my series truck was almost cool to the touch. What happens is, normal white paint absorbs a lot in the infrared wavelengths, while roofing paint is highly reflective.
You can't do too much with your windshield, but good tinting on your other windows makes a huge difference. There is no AC in my Land Rover, and I live in Tucson, and I have gotten the Land Rover to the point where the interior is rarely more than 5 degrees warmer than ambient. Which is still awfully uncomfortable when it is 108 out.
BIGdaddy
two land rovers* sitting in the sun, will achieve the same interior temperature. The lighter color car will reflect more light and will take longer, but will eventually reach the same temperature.
I've seen two separate tests, and the difference was around 15min's or so. Meaning the lighter car took 15mins longer to get to around 120 degrees inside.
This is just normal car paint, or spray paint on sheetmetal with stock insulation.
*(insert any two identical cars)
Sleeping Dog
Are you going to pad it? Perhaps some buttons or tuck and roll?
proto
I've been thinking about doing something like this myself. It would be nice to construct a roof-shield like the LRs use, but I bet a roof rack with a solid floor would work pretty well.
I've also considered stick-on insulation above the headliner:
EX Cool automotive insulation from 'lobcrud'
-- closed-cell polyethylene foam core with polished aluminum facing (about US$40 for a 4 ft x 10 ft sheet, they send free samples on request)
and/or
Paint-on radiant barrier for the outside:
Hy-Tech Ceramic Paint Additive
Heatshield-r20 Insulating Paint Additive
-- these are both ceramic 'micro-balloons' added to paint that act as a reflector and thermal insulator (both products are about US$10 for a gallon of additive).
BIGdaddy's argument has merit, though. If the sun keeps pumping energy into your car, it's going to heat up until it reaches an equilibrium. It makes sense to me that a lighter color may merely slow down that process. But that might be enough to make a difference.
Chonker LMTV
