Pskhaat
2005 Expedition Trophy Champion
...12+ years and i don't think I've heard of a stud failure when not bashed to bits against rocks.
Kinda for me: http://forum.ih8mud.com/100-series-cruisers/68161-how-change-broken-lug.html
The 100 series' lugs are 14mm and though only 5 lugs are present, it represents almost 12% increase in total cross-sectional lug area than the 6 lugs on an 80 series. No rhetoric there, but let's just say that 14mm lug is a tough job to break.
I've always thought of my 1St Gen Tunner as a "Mini Cruiser" this just proves it for me......real Land Cruisers have 6 lugs...
Not in the slightest. Can't realistically get those here, so they do not exist in my book.Does this 5 lug LC change that theory
So why do Land Cruisers, heavier than 4Runners, have only 5?
You said exactly what I was thinking and couldn't figure out HOW to say. One thing that I keep coming back to is that a stud needs sheer-strength due to a sort of "coast" and "load" side to the studs as they mount to the wheel. The larger diameter studs would have a greater shear-strenth so I'm sure 5 of them is as good as the smaller diam 6-studs......There is a LOT more to a bolt circle than just the size of the fastener. The radial distance of the fastener from the center of the hub is actually more of a factor than the size (within reason) of the fastener. A small increase in that radial distance is a huge change in torque transmission ability and a decrease in the leverage that the tire has against the stud....
Assuming that the lug nut is properly tight the stud isn't in shear at all. It provides a clamping force to hold the wheel's center to the wheel hub. The friction created by that clamping force is far, far stronger than the shear strength of the studs could ever be.
Think about a flywheel bolted to the rear of a crankshaft and why it is so important to torque those bolts exactly right. There is no way that those bolts could hold the engine's torque on pure shear strength alone. The only freeway speeds capable vehicle engine that I know of that drives the flywheel mostly by shear strength are air cooled VW's.
That the 80 lug studs are failing tells me that people are using too long of a tool to tighten them with. Going tighter is not the solution to failing wheel studs, it is a cause of that. You can yield a bolt or stud slightly and it will recover ("elastic deformation") or you can go further and stretch it beyond it's ability to recover ("plastic deformation"). Every elastic event is a fatigue life issue (it will only do it so many times before failing), but one plastic event results in a junk bolt or stud.
I always tighten lug nuts with the tool that I keep in the vehicle for changing to the spare.
The real reason is strength.
We have seen many cases of stud breakage particularly in 80 series vehicles. So many in fact, that we consider this, together with sector shaft breakage and exhaust pipe failure, one of the main problem areas of this model.
The problem with the 80 series studs breaking is so bad that I have seen dealers in Venezuela and Paraguay warning customers to tighten them only with torque wrenches.
Having five 14mm studs arranged in a 150mm PCD results in a much stronger assembly than 6 12mm studs in a 139.7mm PCD.
