Wikid
wikid
* Total Visions Products
* Baja Camera System
* Custom four monitor overhead console, with a center section for switching, cb, and keypads
* Two digital keypads controlled by ecu’s to choose four views from eight different camera locations.
* Quad channel DVR with 120 gig HD, GPS tracking and motion sensing for on.
* Custom headliner with sound deadening and insulation
* Allan Phillips Racing X-1 engine management system
* AFE Pro Guard CAI
* Magnaflow with custom hightuck 3” tailpipe
* Camping Labs Roof top tent
* BajaRack expedition syle rack
* Lowrance Baja540C Off-road Navigation
* Engel refrigerator custom mounted where the drivers side rear seat was
* National Luna dual battery controller custom mount
* Sears Platinum marine battery custom mounted over the passenger rear fenderwell (where the subwoofer would be)
* (2)Blue Sea eight circuit fuse panels
* Lightforce 170 strikers
* PIAA 520 lithium ions
* Onzium LED interiors
* Dashboard lightbulb
* Inchworm E-locker guard
* Scubadriver mod
* Bodymount chop
* Cobra CB, Wilson 1000 antenna
* Custom Gear box with tailgate
* Body color matched door handles mirror bases and blacked out mirrors
* Old school white bezel
* Hood scoop mod
* Recovery gear and tools
Planned Mods:
* Suspension
* HD Camera’s
* Sliders
* 35" Tires
* Lower gears
Sponsors
Total Vision ProductsTotal Vision Products: The new standard in mobile vision products
Allan Phillips Racing APR Power - ECU
Camping Labs
Baja Rack[url=http://www.bajarack.com/]:: Baja Rack ::
This is where it all began..
Protecting her bottom
Bud Built Skids including crossmember Sun Fusion Yellow
Color matched door handles and mirror bases. Mirrors and bumpers black, bezel color matched white with yellow letters
Road Armour bull bar, Lil Will CB, cobra wst75, Fourtreks hi-lift/axe mount
Bulldog 9500 with wireless remote
sometimes she is a poser
Raffle swag Inchworm E-locker Guard
PIAA 510 fogs, PIAA 520's on the bar
No.1 Mod Dashboard lightbulb custom installed with 2 face tape.
Only the fearless will follow if that is glowing
wikid
Easy install of supplied switches for all the extra daylight
A little tuck
Body mount chop done with 8ball
Exhale
Magnaflow, custom 3" bent for high clearance
First set of heels
Hankook 285/70R/17
I will be adding a few more pictures with my newly aquired mods soon
Metal-Tech rear tube bumper installed today
First intake
TrueFlow XDi extreme duty intake
Fresh air
Hood scoop Mod. Expanded metal, drilled opening for air flow
One note about this mod. I was playing in some serious mud and snow this weekend in Flagstaff without any increased mess in her engine compartment . With the combination of the intake/exhaust and hood mod, My gears weren't hunting as much going to flagstaff as in previous trips. For those who don't know, Flagstaff is about 6500 ft. I am at 1215 ft here. It definitely gave me a few ponies and torque on the bottom.
WIKID got her new name tag
I have a very good friend who put this together for a Christmas gift. It looks awesome hanging in my home office
I decided to remove the control box on WIKID'S bumper and send it to the engine compartment. Longer cables made it possible to mount in under the XD-I intake with easy access to the plug in for the wired remote. Hopefully I won't need that since I installed the wireless controller inside the control box. Everything should stay more dry now.
wikid
I like the cleaner look under the bull bar now. I didn't like the large gap inside the bumper. It looked unfinished
I decided to go get some steel and fab something up to fill the hole. I went to the steel place and looks through the scraps. I found some 3/4" angle and some plate steel with holes in it, brought it home. 9 bucks is what it cost. I used the dimensions from the cut out and started fabbing,
This is what I ended up with
Here it is fit in place . I used Magnetic strips along the front to keep it in place so I still have access to the winch control bar. I almost didnt need anything since the angle fit it nicely, but I decided to use the magnets for a clean appearance
WIKD has travel assistance now
Lowrance Baja 540c mounted in the Shadow Warrior location with a small twist
I liked the location, but thought it was too far to reach, with my short arms so I moved it back along with adding a fish finder swivel. The mount is 18 guage steel gussetted in 3 locations. the base of the swivel is custom made to use the triangle mount provided, then bolted on. I have tested in on local roads and highways. I think it will be fine on the trails too.
I did the headliner pull of use from either the passenger or the driver. It has no affect on my vision
New Engel frig mount
I decided to mount my frig in an alternate location. I rarely have passengers and even more rarely have more than one passenger. I decided to remove the drivers side rear seat and make a frig mount, where the seat was. I used the exsisting seat mounts, so I wouldn't need to drill more holes in my truck. It sits nicely one the mount and is secures with tie down straps. The front seat will move all the way back ( for those of you with long legs). The refrigerator door opens all the way, without contacting the ceiling. It is very secure and allows me to have the entire back for tools trail stuff and other storage. This was part one in my quest to organize the truck for longer trips
Here are some pictures
The seat base is contoured, so I made up the contour with 2 more 5/8 thick plywood pieces that level out the area.
I reinforced the front for a more solid strapping point
I added some carpet that I attached with 3M 77 adhesive and staples for the edges
Final result is a very sturdy, easy to access refrigerator. I tested pulling the basket , opening the door and removal of the refrigerator . It would be about a 30 minute change over to reinstall the seat.
The frig mount does not interfere with the other seat at all, so it could be opened or closed with no issue
The most difficult part of this mod was trying to mark the holes in the existing seat mount. It was a funny angle and had to try a few different methods of figuring out the hole locations. Once that was done, it went fairly well .
Rear dual battery set-up
Here is the result of my dual battery system
Behind the bottom section is a power inverter and the dual batter solenoid + controller. the box above has the optima red top battery and of course all the wiring necessary for smooth operation
I will go through the steps
Wiring
I bought a rear winch cable kit for a bulldog winch which included 24 ' of Red and Black 2 guage cable, a quick disconnect and some wire ties
about 100 bucks total ( Wire aint cheap anymore)
I ran both cable from the front battery along the firewall throiugh the passenger side grommet.
I pulled the lower kick panel and all the door jamb trim and carefully ran all the wires through to the back trim by the rear door. Pulled the body trim away and ran the wires through to the back fenderwell
wikid
The Box
I made a mount in the location of the sub woofer and built it up to the level I needed to be above the trim
The next part of the puzzle is the faceplate for the bottom section which will be removeable when servicing is needed
Fiitting the important parts is next. I wanted to make sure they had breathing room Selenoid, power inverter costco special 1000 watt Zantrex
69 bucks and change
National Luna Dual battery 245.00 with remote control for dash
Fitting the lower faceplate
I bought some angle at Lowes 9 bucks Cut it up and welded it together for the battery box
Test fit it Ohh yeah the Sun Fusion color was my own choice
I do have a few extra wires I didnt mention 1 8 guage coming from the front battery for future reference and the remote controller which goes to the dash for the dual battery controller
Fabbing the top of the box
wikid
I have used 5.5 inches past the fenderwell. the box is tight and secure. It will also house my own version of a quick disconnect battery jumping system along with a blue sea 12 curcuit fuse panel .
I have complete control of my electrical system without compromising space. I will be adding a storage compartment for the rest of my rear area that will keep everything safe and free of lauching.
Once again Here is the complete (for now) version
I added a tailgate to my storage box that will serve as a table as well
Its made of 1" square tube skinned with 18 guage steel on both sides
As you can see some of the steel in missing from one side . I stitch welded the skins on and miter cut the 1 " tube . It actually is very square.
I used 3/16" cable for the table support. 1 " angle welded back to back for the eye mounts on the box.
It's painted yellow inside of the table , which is exposed by the plasma cut letters and added led lights inside on either end .
It was meant for function but added some form to it as well. It's hinged using 4.5 " bearing hinges used for large doors. They are welded to the frame. All in all it's very strong and would support any weight I would put on it. I also needed to modify the battery box so the cables could be mounted correctly
This is phase one.
After Ouray I will have an extender to clamp on the table to make it like a dinner table. Trek poles will act as legs to support the extension .
All of this will be done with lightweight material and store easily inside the storage box area
This side is only primer . It will be painted a semi gloss black
Metaltech Rear bumper
wikid
WIKID has eyes for you... Beginning of Baja Camera System Install
While I am doing this project I am adding stuff as I go
Since the headliner is down I am doing a few things to make life easier.
Wilson 1000 antenna roof mounted. Say good bye to the lil will Mag mount. You won't see cables on the roof now. This antenna is about the best you can get for a CB The really nice feature is that you can unscrew the base of the antenna with you hand and screw a cap on the stub so you don't have to have the antenna up all the time. Its just a little black cap that is left.
I decided to quiet the beast some with a product from Second Skin Audio
Sound Deadening Materials for Noise Reduction from Second Skin
The product is called Damplifier Pro. kills, vibration, heat and noise
It comes in 12"x20" sheets that have paper you peel to adhere to the roof. Its very sticky and I cannot see it coming off even if you begged it.
Next will be another insulation product I glue to the face of the Damplifier Pro
Its about 1/2 to 5/8th thick called "heat wave" and has great insulation properties
Second part of insulating
I left it short till I secure the rest of my stuff but it will be finalized after it it all done
Today was the beginning of the camera mount and wiring days. I completed 3 camera installs and ran about 80% of the wire/cables Location, location, location, was the theme of the day.
The picture below shows 2 of the 3 cameras installed today.
Camera 1
Drivers side on the roof Narrow view camera that shows lots of distance but not as much on the sides
Camera 2
Passenger side a wide angle but not much distance
My logic behind where there are mounted is..
I wanted to be able to easily clean them without having to make some kind of boom to reach the center ( remember I am short) I decided to follow the line of the washer nozzles. With that I also needed to establish an axis for where center would be in front of the truck. 8Ball and I worked it out with much effort
Side view Note: the covers have not been placed untill they are sealed with silicone into place.
A longer view
Continue next post
wikid
Camera 3
Rear roof . I decided a narrow view camera would be best for most conditions since I will also have a wide angle camera on the bumper
Progress on the overhead console
I used headliner material to cover the monitor pods and made a center section which will house both of the keypads, cb radio and a few other goodies I have planned for it.
Here is a sample Keypad that will control the cameras. The center was cut and formed from 18 gauge steel. Angles were important along with forming a rigid back edge
One more view from the back of the truck.
The top edge should be the approx height of the headliner
I am working with Rod from Total Vision of Tucson, AZ. Total Vision Products: The new standard in mobile vision products I gave him the thoughts I had and he developed the system. We are working together with the install. So far my end of the install is almost done. Rod is designing another system that could be a great addition to the FJ crowd along with others who may want something like it. The system being designed is not this involved for the install. Mine is just over the top. I will post more details about that soon
The wife's TT will be fitted with that system this weekend
Just a small update. Besides all of the wiring I accomplished the oh center console is painted and fitted.
I am pleased with the way it came out. There are still some things to add to it but it is on the way to being complete.
Next will be one more set of cables to run then the headliner can go back up.
I am waiting for the cables though
I will start with a view from the drivers seat while driving home from Tucson. The left picture is facing forward from one of the 2 front facing roof cams. The right picture is the long view rear roof cam picture. I was hoping to catch this guy pickin his nose
We have most of the system in and 2 of the cameras viewing.
There is lots of wiring and configuring to do. This is the semi complete oh console after today's progress
More to follow..
wikid
Even though it doesn't look like it, we are fairly close to trimming everything out and doing final adjustments, before the headliner goes back up. Its a slow process because this is totally custom and there are many things that come up while we progress
Wiring in the 2 ecu's that are controlled from the keypads on the console
I can't wait till I can start putting stuff back together. It seems like the more we do the more we take apart, but that's the fun of making something from nothing.
The part you don't see is the DVR. I forgot pictures of it, but pictures will follow
More to follow...
wikid
I decided to make a harness for all the switches in the OH console. I ran one 12 gauge wire for power and a ground. Then soldered and wired each switch. I used (2) 5 wire cables to use as trigger wires to run to all of the accessories that will need to be switched. I should never have to pull anything apart in the roof area to add anything from now on .
This is just a pic of all the switches being tested
Of the 9 switches in the console 5 are already dedicated off-road light and The Baja Camera System.
Today is camera install day part 2
Here is a rock spotting camera located on the front drivers side. The passenger side has the same
I drilled a 1" hole angled down and painted the exposed edge. The camera's have brackets that are epoxied in place
Approach angle camera
Here is the departure camera or backup cam
Rear axle cam protected buy my skids and with clear view of the dif and inner tires
Quad channel DVR with GPS tracking and alarm mode
Here is the wiring finalized. It will not move or show after the headliner is installed. We still have to test the whole system before the headliner goes up just in case..
For some reason I could not get this image to turn the right way up.
More to come
wikid
Here are the 2 ecu's wired and ready for testing. I am going to make a wire keeper for the top of this where all the wires that come out of the ecu's will so have support above them so they won't wiggle out. Testing mode doesn't require neat appearance til I know its right
As part of my Camera mod I have had to relocate a few things
This is a picture of the way my GPS was mounted before the Camera Mod
Since this is close to the configuration I am dealing with now the GPS needed a new home
Here is what I fabbed up today to make that new home for my Lowrance
Pardon the sloppy look I tack welded it in many places not to distort the metal. I will clean it up and paint it.
This has a swivel mount from a fishfinder like it was in it's previous location
Here it is where it will be mounted. I still have access to the transfer case shifter and all the controls on the dash along with still being able to see the radio controls
I made the angles specific so I could still shift with no interference. Its 16 gauge steel with formed edges and 1 inch bar stock to re enforce the lower plate then 1/4 inch dowl rod bend and joined in the middle with a baseplate welded on top to attach the mount
I can now reattach my rear view mirror.
I may mount it with industrial strength velcro but am still pondering it as of now. I am open for suggestions on the mounting though.
Thanks
Don
wikid
Ok After testing my system in a local rough wash area, I cannot get the video system to mess up so I think it's ready to finalize. The picture reflects wires secured with the sound deadening. I used strips of it to stop possible wires coming loose and rattling in the headliner. The sound deadening is extremely sticky, so I doubt it will come loose. Everything else was wire tied into position
Everything in the rear is secure and the next step will be to secure the OH console and tie wires out of the way.
The DVR is now mounted in a different location so it will be easier to control it with the remote. Top of my rear Battery box is where I chose. If you look at my gear box, on my build, it fits against the battery box so you only see the carpeted boxes instead of wiring
View from the passenger front. If you look closely you will see that the DVR is actually recording
It felt good to install trim panels. It makes me feel like progress is made
Next stop, drop my truck off to I-10 upholstery, to make the headliner transition to the new monitors.
This will be more of a temporary solution, I plan on having the headliner remade after Overland Expo.2009 . Wikid's Camera system will be displayed at Total Vision Products: The new standard in mobile vision products booth
Taking matters into my own hands I will post up the headliner install
First picture is what needed to happen to get this project underway. My wife and I peeled the old skin off the headliner. It took some time and patience, but came off nicely
Presto its magic. Off with the old
The headliner color I chose was a graphite. I wanted to rich it up some, since I was changing it anyway.
The method we chose was to lay it out then fold it half over and begin spraying the headliner glue in a section at a time
The last part was where the modification was needed for my monitor pods
wikid
Since I changed my mind on colors I had to redo the monitor pods in the correct color. That took the most time since I had to pull everything down and pull all the monitor cases out to make a clean install over my custom console. It was worth the extra effort for sure.
Installed and making small adjustments on it
After taking a ride it is more quiet than it was before all the insulation.
I bought too much headliner material because I wanted to be ready for problems. 8 yards of headliner, 3 cans of headliner adhesive and 6 hours is what it took to do it from start to finish. $99.89 is what the project cost me.
My wife was a really big help on this end of the project. I am fortunate she allows me to play with my toys and humors me when I ask her opinion of my latest brainfarts
I am so glad I didn't leave it up to an incompetent shop to do this. It came out the way I wanted it to.
The jury is out on the gray accents, visors etc they actually look pretty good when you see it in person. I may or may not recover them to match the headliner
This project is pretty close to being complete. I have to put my Don box back in, the frig, the dvr and I am ready for some awesome trail video.
One more picture to show the complexity of the orientation of the monitors. I wanted to make sure I could have full use of the visors, so this part was difficult and I made many adjustments on it.
Thank you everyone.
Comments like these have helped in my motivation, when it seemed as though things were not happening as they should. It's all good now.
Its been rewarding to accomplish something that has been in my mind for awhile.. The bonus is, it worked out better than I even expected to. It's been a long 6 or 8 weeks , but I really enjoyed the challenge. I expect to get lots of trail video. Group runs should be fun along with trail interviews.
Don
Next .. Wikid needs a good cleaning so she looks good for the expo this weekend.
wikid
Here are a few shots from the white blind run through the course
This was the very first time I have ever tried to drive without having the use of windows. It went well. I found a few views I still need to make it easier, but it was fun to do. Best thing is wikid is still in one piece:cheers:
The response to the Baja Camera System and my truck in general was overwhelming and very rewarding.
Thank you Dan and Jessa For helping out with the window coverings and especially to you Jessa for doing some creative writing on the front windshield
After getting my Transmission replaced it was time for a shakedown run.
My buddy 8ball and I decided to run the back way to Crown King. I ran the DVR the whole trip, however we are working on how to transfer video to a usable format. But the Camera system had no issues at all. I pushed it pretty hard taking the most difficult lines I could so I could get some good flexi video
Here are a few still images from todays fun
8ball always gets the most out of each run . He's sporting his new 35 KM2's and 4.88 gears
A few jeeps came up behind us so I took a few shots
Since I was pushing it, I tried some really hard lines and had a few situations like this. 8ball would be disappointed if I didn't post this one, This was 1 of 2 strap sessions. The first one was so I didn't roll
I found a few rattles I need to find and address but overall it worked flawlessly
Here is another pic of the fun
thanks
Don
Petersmithinak
