mk216v
Der Chef der Fahrzeuge
Building a new F350/flatbed camper. Won't be a daily driver, so all adventure "gear", as in at least 1 winch, will be staying on the truck at all times. I've been pretty set on aftermarket front bumper(Warn Ascent) w/ bull bar for better approach angle, some animal strike protection, more lighting. So figured I'd mount a 12.5k winch in it.
And was dreaming about a fixed rear (probably 9.5k, with snatch block the double pull will be fine) winch as well.
But in discussion with overland friends, the topic branched out to;
--Why a front winch like everyone does, especially if there's a greater need for self recovery vs recovering others?
--Wouldn't a rear winch make more sense for self-recovery(ie driving into something and need to winch yourself back out), and if I needed to recover someone else I just turn the truck around?
--And then what about fixed(front and/or rear) vs movable(ie ability to move a single winch on a plate, lets say single 9.5k, from the front hitch receiver to a rear hitch receiver)?
-Dual winches add more weight(figure a 2nd winch is an add'l 100lbs), add more cost(especially if needing to have a custom fixture built in the rear to hold rear winch).
-Single winch saves some weight(about 100lbs), saves some cost.
-Movable saves some weight(although again for me, I'll always have at least 1, if not 2, winches on the truck, so it's either 100lbs or 200lbs), and saves some cost(can just install the front and/or rear winch in a front and/or rear hitch receiver). (note; only other thread I found regarding this topic; https://expeditionportal.com/forum/threads/removable-winch-mount-in-bumper.189021/#post-2419981)
-Fixed adds weight(possibly 100lbs more if adding 2nd winch), but means no hassle and no lugging a heavier winch/plate around in times of emergency or peril.
Looking forward to thoughts, especially from those who have/had dual winches, rear winch only, and/or movable winches. Thanks all!
