xcmountain80
Expo, good afternoon I'm looking to replace or modify my current winches solenoid pack. I have a T-Max 9k with a sealed typed solenoid in a sexy aluminum housing. It works but the plug assembly leaves a little to be desired. The massive plug is a insert and twist but it doesn't always make proper contact for the reverse feature. A little fiddling is required.
My thought was to either replace the entire unit, or after a quick google search Warn makes an extended mount for a 7 pin (IIRC), which means I could remove the big twister and replace, solder, and rework the case I accept the more reliable 7 pin.
Thoughts?
Thoughts?
