I am working on a 12 volt portable power system for camping. Looked into Goal Zero and others and they are too expensive as well as if something goes wrong not easily able to fix. by building my own I can customize it to for my use as well as if something breaks I can purchase off the self parts to fix it. Currently this box will mainly be used to power 4 Goal Zero lights that pull a total of 1 amp for all 4, Run a 12 volt pump to blow up the air mattress, a battery charger to charge small batteries for flashlights as well as charge cell phones and tables and to use a 12 volt shower pump. in the future this will be charged by a solar panel which I have not wired yet but have put in a connection. Below are a few pictures of what I currently have. Any thoughts and ideas would be appreciated. This is still a work in progress as I do plant to add a battery meter to the front. If anyone knows of any good one that would be great.
This is the box it is in
This is the side You will see I have a solar connection not yet wired, a remote connector this is used to plug anything in like lights and be able to turn it off with a key remote. the last two connectors are always hot, what ever is plugged in with automatically work
![IMG_20161016_132325.jpg IMG_20161016_132325.jpg](https://expeditionportal.com/forum/data/attachments/287/287583-71f368808f1de07e9fb86f77803dbe38.jpg)
This is the front. the button switch controls the 12 volt cigarette style plug and the 5 volt usb plugs as well as the battery charger
![IMG_20161016_132430.jpg IMG_20161016_132430.jpg](https://expeditionportal.com/forum/data/attachments/287/287584-85e851e946c885afbef7d670870de687.jpg)
This is the top. I have the key remote that controls one of the plugs, I have a flashlight that can take either an 18650 or three AAA with adaptor, and last I have a 12 volt battery charger that can charge 4 AAA up to 4 18650. Off to the side you will notice storage for a 400 watt inverter, some cables, and a USB light
![IMG_20161016_131828.jpg IMG_20161016_131828.jpg](https://expeditionportal.com/forum/data/attachments/287/287585-e7947808544de0f884b56ee48f2a2514.jpg)
Under the hood is a 28Amp hour battery and all the connections. I don't have any fuses yet I may add one to the always on as this connection would be used to add an inverter if I wanted to.
![IMG_20161016_125817.jpg IMG_20161016_125817.jpg](https://expeditionportal.com/forum/data/attachments/287/287586-2c70a7e034229b67ab23eae1ad3b9046.jpg)
The top also has some storage for adaptors to convert the Anderson power poles to SAE as well as some other adaptors.
![IMG_20161016_131655.jpg IMG_20161016_131655.jpg](https://expeditionportal.com/forum/data/attachments/287/287587-a9d8f7ad98eae97fb3029b2aa9856b42.jpg)
![IMG_20161016_132422.jpg IMG_20161016_132422.jpg](https://expeditionportal.com/forum/data/attachments/287/287582-9ba0d68f37462ec90c35268e4ab7978a.jpg)
