Louisd75
Well, after bouncing back and forth between an IC 7000 and Kenwood D710A, I've gone with the kenwood. I really liked all the features of the Icom, but I think for the kind of stuff I do, being able to monitor a 2nd freq turned out to be more important to me. That and I could nearly buy two Kenwoods for the price of the Icom
Now I'm working on installing the radio. It'll be through the roof of my Tacoma. The inside mounting of the radio and tranceiver will be a little tricker. I don't want the radio on the floor, and as anyone with a Tacoma will tell you, there's not really a whole lot of space inside. I did find an area that seems to be used a lot in Australia (thanks Australian 4wd Action!) but not so much up here, and I'm taking advantage of it. First, we begin with the mocking up. I had a large remnant sheet of masonite (guess it's not called that anymore?) leftover from another project, so I didn't feel bad cutting shapes out of it til I got things right. Here's the final iteration of the template cutting, along with the mockup of it in position in the cab of my truck being held in place by my lovely and understanding volunteer:
Up forward it will mount to existing holes for the front map lights. In back it will mount using the existing dome light holes. It does not block any of my view out the rearview mirror.
Now that I had the template, it was time to move on to the real deal. I used 1/8" hobby plywood from Hardware Sales up here in Bellingham. So far I've used two 12" x 24" sheets. I'll spare you the tedious process of fitting and gluing all of the parts and skip right to where it sits now:
Yes, it's upside down You can see the D710 head. Just ahead of that is the Scangauge. Aft of the head, the receiver will be mounted inside on the large flat region. I'm also planning on moving the rocker switches for my aux headlights, fog lights, and reverse lights onto the console, likely just sticking through ahead of the receiver. I've angled some of the corners on the sides so that when I ********** my head into it, it's not a 90* corner. The console is also sitting on top of the perforated metal I picked up to make a couple of panels out of. I don't want the receiver to be completely enclosed because of heat, so the aft end and the opening just aft of the radio head will be made with the metal. When it's all done I plan on covering the wood with vinyl cloth.
Here's how much space the receiver will have. I'll be using the factory mounting bracket to install it:
It's very likely that I'll need additional speakers in order to hear the radio. The one that is built into the receiver is small and is going to be fairly enclosed, even if I put a hole in the bottom of the console for it. I'm going to give it a shot without them, but when I do finally decide that I need extra speakers I've got room between the receiver and the rear dome light to install them.
That's about where it sits right now. I feel like I'm 90% done with 90% to go, but I'm getting there. I'll try to update more as it nears and reaches completion.
