Nonprophet
Hey all you Wildernesters out there--I need to attach my Yakima 1A towers to my WN camper. Yakima shows 2 clip sets available: one goes flat on top of the camper, the other attaches to the side.
I know the WN's have the reinforced mounting pad on the top to install a roof cage/rack, but the Yakima top-mounted clips have a bigger footprint than the built in mounting pads on the WN roof, and so they look kind of funny installed that way. If I install the clips on the roof, that means that I have to deal with nylon lock nuts on the inside of the lid (where the mattress goes) which would protrude into my mattress/camprest pad and/or be a nice knee banger....Also, by using the side-mounted clips the racks will get a good 4-6" wider spread (space between the towers on each bar) and also a wider spacing between the bar sets which would be nice......
I know that using the built in rack pads on top would be a little stronger, but the WN roof/top is already much thicker and stronger than a regular canopy in order to take the 1,000 lb load of two people plus gear up there, so I think the side-mounted option with the metal backing plates should be plenty strong--especially for lighter loads like canoes, kayaks, bikes, etc.
I've seen a few pics of here of WN with racks on them--how are you guys mounting your Yakima systems?
Thanks!!!
NP
Thanks!!!
NP
