Yet Another Swivel Seat Question...
Amazon flat swivel base, says i it's not for automotive use but I installed it on the passenger seat to retain what I suppose is called the under seat glove box. From what I can tell it's stronger then the bolts going into the floor so I feel it's plenty safe. Probably gives an inch or so of seat lift.
On the driver's side I assume it would work there assuming you remove the steering wheel but probably not worth it.
This one?
K & M Swivel Pro Seat Swivel, Model# 5006
I would like to retain the underseat storage as well.
Thanx in advance.
Jim
That's the one. Welded to the seat base and bolted to the floor. Not a dot seat base but I feel it's plenty safe.
It also doesn't have the inner tube to run the wires for the heated seat and airbag. Easy to unplug the wires to swivel and in any case mine has the passenger side airbag delete and the heated seat is weak at best so I just leave them undone most of the time.
Fj89
