pratty85
Hey all! I have been thinking about doing a build thread for awhile, and have a place to show my van's progress from the time Chris at UJOR purchased it till now.
When Chris first received V3:
![V3 when Chris got it.jpg V3 when Chris got it.jpg](https://expeditionportal.com/forum/data/attachments/76/76398-54df7847d1a55911e55a382df724904b.jpg)
When I first received V3
![Finished!.jpg Finished!.jpg](https://expeditionportal.com/forum/data/attachments/76/76399-660552dacf53e9046535a393f275e649.jpg)
Baja rack installed:
Trail Ready Front Bumper, fender flares, Highlift mounted, 2003 van grill, and 4" TB Exhaust installed:
I am currently working on the interior of the van. I chose to do a Dynamat Extreme Kit from Quiet Ride solutions, for insulation, and sound deadening. They were very helpful and easy to work with and made sure I have enough material to cover the entire inside of the van.
For the vans walls and ceiling I chose to purchase an Adrian Steel Poly Liner Kit.
I covered the floor in 5 layers of Duplicolor Kevlar bed liner. I will be putting the Dynamat over that followed by plywood and an Adrian Steel Rubber floor mat.
For the Doors I chose to buy and install aluminum panels to replace the factory cardboard door panels. http://plumbingvans.com/cargo_vans/door_panels.php So I would have a solid mounting surface. I used fiberglass insulation inside the hollow cavities of the doors.
I have a custom van sofa bed ordered that should be here in a few weeks 68" wide and 48" tall when folded down. I will update with pictures as I install each item.
Hope you guys enjoy!
![DSC01819.jpg](http://i867.photobucket.com/albums/ab233/pratty85/DSC01819.jpg)
![DSCF0694.jpg](http://i867.photobucket.com/albums/ab233/pratty85/DSCF0694.jpg)
