Stumpalump
I drilled a 3" hole in the side of the van and inserted a 3" pvc plumbing cleanout fitting that came from Home Depot. The cleanout fitting has a screew in cap to block the hole from the inside when not in use. It sticks out 1.5" to connect the hose to. It was $ 4.19 and everthing fit just perfect. I ran the Zodi off of the BBQ tank but can use two small coleman cylinders.
![image002.jpg image002.jpg](https://expeditionportal.com/forum/data/attachments/54/54167-9348a454c68bc0eab35e606cff00cbba.jpg)
Zodi tent heaters are getting harder to find but they are around if you need to knock the chill off on a budget.
![image001.jpg image001.jpg](https://expeditionportal.com/forum/data/attachments/54/54168-880cb0b02e4ca9ff429debb5ecd7687f.jpg)
