gabepari
Which did you prefer and why? Thanks
Leafs by far. 8" of buttery smooth damped travel (about 3.5" of bump and 4.5" of droop) gobbled up every bit of washboard, and Racetrack Road HAS some washboard
I agree totally, but I am a loyal Dexter user and had to defend them as being a poor choice. Also a much easier set up as you have stated and it makes the frame much stornger, with the added cross bar so to speak. I plan to put a lot of miles on my new trailer this summer, pretty much anywhere and everywhere. We will see how it holds up. If it fails you guys will be the first to know, as I am want it to be the best I can make it.
Again, there is no need for a 3400 pound torsion axle on a expedtion trailer. Our max weight would be 2000 pounds is my guess. Mine is right there, I use a 2500 pound axle on mine, works perfectly. Some where along the line we have decided that 3500 pound axles are the right application. I understand the stronger bearings and all, but you can order those with the 2500 pound torsion axle. I think all of the problems people are having with them are related to over doing the axle weight. Most who use spring axles use the 3500 and down grade the springs/leafs. With the torsion axle you can order down to the weight you need. It is decided by the rubber in the center. If they are no ordered properly you will have problems as there really is no after modification.
Dexter offers the axle from 1900 to 3400, then 3500 to 4900, 5000 to 9900. You can chose any number in between and they custom make them for you to your requirements. The new 5 and 10 thousand pound axles offer a air bag, but do not offer if below as of yet.
You can order pretty much anything from disc I have heard to parking brakes and any bolt pattern.
My guess is that AT ordered a 3500 pound axle, which would be the norm. I can just imagine how rough it would ride and bounce would be unbearable, with no way of correcting it other than overloading the trailer, which would be near impossible.
Torsion axles have to be ordered for specific weight and use. If you don't I can see how the problems would occur.
I know that you guys offering opinions already know this, but for the guys that are just learning about trailer suspensions, dampening and geometry should be mentioned also. Shocks can be used with most any suspension and may have relieved some of the issues that guys are pointing out. For example, add shocks to leafs or torsion axles and they will behave very differently. The springs are only part of the equation.
- Springs (leafs, the rubber inside a torsion tube, torsion bars (different from rubber torsion axles) air bags, etc...) support weight, that's why properly choosing and loading springs is so important.
- Dampening (shock absorbers) control the motion of the springs and how the springs react to different terrain.
- Suspension geometry determines the motion of the axle as the suspension cycles. Torsion axles move back and up, as the springs compress. For the most part, leafed axles move up and down. Moving back and up will be better for deeper pot-holes and whoops and have less benefit for washboard.
All this given, if you don't want to figure all this stuff out on your own, I'd recommend buying a suspension from someone you trust.
I'm no suspension expert but I would think shocks would only improve any suspension provided the basic suspension be it leafs, torsion axle, air bags, whatever is correct for the load its carrying. I believe Airstream which is a pretty well respected company as far as trailers are concerned uses torsion axles AND shocks, I can't help but think a company which has been building trailers for over 70 years has a pretty good formula for success? Again I'm just speaking from an outsider looking in.
I don't follow you. Again I'm not a suspension expert. What is it about 1500 lbs. that makes things that applied at 1600 lbs. change?
