Well shoot, guess it's my turn
Finally got around to some more little things I've been planning on. I upgraded my headlight wiring harness with one I picked up from SUV lights.com quite a while back. I also wound up replacing my headlight bulbs because one of them decided to burn out. I can't say how much of a difference the new harness made vs the new bulbs (Sylvania Xtravision), but the before/after is remarkable. Things are much, much better now.
I also went ahead and installed a dual battery setup. I picked up a dual battery tray and National Luna intelligent split charger from Columbia Overland. Installation was a little bit of a pain since the dual battery tray needed to use space that I had already used running winch power cables, aux headlight relay and the new headlight harness relays. Fortunately I was able to shift things around enough to get everything to fit snugly. For batteries I went with a pair of DieHard Platinums in the group 35 size. They both fit into the new battery tray, but I had to trim some plastic off of the battery casings. There was a lip in the casing at the bottom that I shaved off with a file in order to get both batteries to fit.
After fitting the batteries into their new home, I started wiring up the split charger kit. I'd gone with the kit after somewhere getting it stuck in my head that it came with larger gauge cables than it actually does. I had planned on wiring it up following the schematics for a "Split charge system with a winch fitted" seen on page 10 of the manual (http://www.nationalluna.com/Datasheets/Split-charge manual.pdf). To do so, you wire the battery without fuses, which means you need a heavier gauge wire than what the kit comes with. I was also a little underwhelmed by the battery terminal clamps. Basically, what I should have done was to buy the intelligent solenoid and the dual battery controller and saved myself a hundred bucks or so. So here's your opportunity to learn from my mistake. If you're using a winch, it's probably cheaper to buy piecemeal. And now the real reason you're here: Pictures. I've still got a little bit of tidying up to do. All of the cables will get covered with split loom tomorrow but you can get an idea of how things ran:
I mounted the isolator solenoid on the driver's side of the engine compartment near the brake booster. The small relay mounted just forward of it is for the driving lights. The main battery is inboard, the aux battery is outboard. The winch positive and negative cables connect to the main battery. My aux fuse block power comes off of the aux battery. The had the 1aught red cables and black cable made up for me, ran about $50 with the connections crimped and heat shrink put on. The price also included the new battery terminals for the aux battery.
I ran the cable for the controller from the isolator solenoid through the firewall, under the dash, and up the A pillar. I taped it in with all the other wires I've run through here, and routed it up to the rear view mirror under the headliner. From there, I ran it into my overhead console and popped it out the side:
And it works!
In other projects, I've found that the Leer-installed Yakima roof rack track was leaking into the bed of the truck. Unfortunately, I didn't catch it for a few months (sometimes working at sea sucks). The sleeping platform didn't fare too well, so now I'm working on removing rotten moldy wood and deciding whether to start anew with marine grade plywood or salvage what I've got.
There isn't a whole heck of a lot of new stuff going on with the truck. I took part in a few day run down part of the WABDR with Washington Taco and some friends from the Northwest Overland Society. We ran from north to south towards the Overland Rally in Leavenworth WA, but I had to bail out in Chelan due to my schedule:
Washington Taco's rig:
I've been busy repairing and getting a kayak seaworthy again, but since that project is winding down, I've shifted my focus back to the truck:
I've added some padding to the center console of the truck where my elbow goes since there wasn't any before: http://www.expeditionportal.com/for...center-console-arm-rest?p=1168411#post1168411
I've also installed a Green Light Labs GPS 710 module for my radio. The GPS puck mounts out of sight behind the rear view mirror and the cables pass into the front of the overhead console.
It's very easy to install, essentially plug and play. There are a couple of settings to change on the radio but the instructions detail how and what you need to do. It's nice having a redundant GPS that's a part of the radio. What I did not realize is that the GPS module is not compatible with Overland Navigator. I don't run O.N. at this time, but I may have gone a different route had I looked into it a little more and realized that the two won't work together.
I'm planning on starting a version 2.0 for the overhead console. The kayak project has given me some good experience working with fiberglass, and I think that's the route I'm going to go with the next console. I'm toying around ideas for making a mold so that I can make more consoles. I know that there's a market for them, I just don't know how much of a market there will be for 1st gen xtra cab tacomas. The contours on the headliner, distance between sun visors, and location of the overhead lighting will make it very difficult to go with a one-size-fits all sort of approach.
Anyhow, that's where things stand today :)
Bicycle mounts -- Solved!
So, with the wings of the sleeping platform folded up I'm able to store a bicycle on each side. Unfortunately, I never really had a good method of securing them. You don't want to use too many tie downs because then it's a pita to get the bikes out. If you don't use enough, they tend to wander. I'd been using a bike tight mounted to a board that spanned the gap between the bedside and the sleeping platform, but that was far from ideal. I can say that I now have a good solution:
More info can be found here:
http://www.expeditionportal.com/forum/threads/82987-Core-Trax-Bike-Mounts?p=1170134#post1170134
I think the overhead console idea is awesome! There are plenty of 1st gen tacos running around in the expo/off road world. I doubt you'd sell a million of them but if you got the process to where it didn't take too much labor I bet you'd be able to sell enough to fund some future modifications to the truck.
Love your build.
you sir.. are AWESOME!
Naah, I just try to enjoy the heck out of my time on dry land. Half of my year is spent making up for lost time from the other half of the year I'm busy walking around on ship engines:
That little fella is only about 15,500 horsepower and is one of four on the ship I currently work on.
I've been giving a bit of thought to this. I've been playing around with the idea of making a mold that would allow me to make them out of fiberglass, which would be far less time consuming than the one I made. That being said, the one I made wasn't difficult, it just took a little bit of time. The only tools I used were a cordless drill and a jigsaw. Throw in some masking tape, glue and epoxy and there you have it. The most difficult part was getting the headliner contour close, and it wasn't really difficult, just awkward and time consuming. At this point, the biggest thing holding me back from making and selling them would be litigation. It's not exactly soft or light and it's in the general area where your head may want to be in the event of a rollover. I don't think that this would be an issue for most people, but all it would really take is one person with a better lawyer than I could afford to make my life pretty miserable.
Well, you've got me beat by about 58,000 horsepower...
Really enjoying following your build - I might get a thread of my own going at some point in the near future.
How do you like your 2 meter rig? Seriously contemplating installing one in the empty DIN slot below my stereo.
Stay in touch, I'll be back your way on the 3rd.
I'm liking the HAM setup that I have. It's handy being able to monitor multiple frequencies. I also like being able to use the radio as a backup-backup-backup GPS (which reminds me, I need to dust the maps and compass off to make sure they still work). You may run into problems with the 2m in a DIN slot with overheating if you go with a higher power units. I haven't had any problems with my setup in the overhead console but I can hear when the fan kicks on and off. Don't forget, if you go 2m you'll need an FCC license. I have had no problems with the CB where it's mounted, though for some reason some people can hear me just fine and others can't hear me at all. When we were on the Christmas tree run I could hear John but he couldn't hear me, but Grant could hear and talk with both of us. If you decide to go with a CB in addition to the 2m, let me know because I've got an SWR meter for tuning the CB antenna.
Have a safe trip and drop me a line when you're back in town
I was a little apprehensive about taking the Technician license test, but after doing a few "practice exams" online it looks like tha majority of it is basic electrical theory and etiquette. Really like the idea of having a 2 meter rig in the truck, and the APRS with GPS interface as well. Thinking of putting in a CB as well, one like the Cobra 75 remote mount. I'll recess the connector into lower dash, or somewhere else out of the way, going with a self-contained unit because I don;t really anticipate using it for much else than trail comms., and want to keep my cabin as uncluttered as possible.
Amazing how much time can be spent thinking about trucks...
Looks like there is a M & G on the (10th?), I'll be there.
Standing by,
Jake
Just a little maintenance and repairs. I beefed up the endcaps on the truck after they began to fail: http://www.expeditionportal.com/forum/threads/113203-1st-Gen-Endcap-Mod
Before that, my headlights began flickering. I've been running a wiring harness upgrade from www.suvlights.com (a website that no longer seems to be working), which is a plug and play harness that uses the voltage from the stock headlight wiring to activate relays that power your headlights directly off the battery. The aftermarket wiring is a larger diameter and it definitely improves the brightness of the headlight. The downside for me is that the most convenient way to install the harness put the relays outboard of the Columbia Overland dual battery tray. Which means that when the relay burns up like this:
you've got to pull both batteries in order to get to it. Ugh.
In other news, I've got my toe in the market for an additional truck. The most recent modification to my life doesn't fit behind the passenger seat:
She's already got me wrapped around her little finger, and I do mean little. How the heck can they be so small? We've been walking the paths around the house lately and it's been a blast. I can't wait to start traveling with her.
I've been looking at the doublecab offerings from all of the truck companies but we're still at least a few paychecks away from being in the market. I'll be sure to ignore all of the other threads and start a "What truck should I buy?" thread before I do :sombrero:
Fj89
